Help restrain me (on the track).
Addict & Guru
(also posted on the 993 board)
I've decided to install a BK harness bar & 6 pt. harnesses (stock seats). I've found a harness bar. Anyone have the "quick connection" BK harness mounting hardware (R-9001 & R-9003) they want to unload? Also, although I would not trust used harnesses from a stranger, anyone here have a pair of 6 pts in good shape they no longer need?
DE use only so need both seats equal & technical certifications not required.
Pls PM or email me here.
TIA
TIA
Dan, my friend races a D962 and we have to keep our harnesses within 2 years...so he has recently replaced his Sparco harnesses.
He has a pair of Sparco BLUE 5-points, the $200 ones that I know he'll let go for $150 for both sets. The 5th point can be replaced EASILY with a 5th and 6th since it's just a separate belt...for about $18 each, I believe.
I will PM you.
I will PM you.
Dan I MAY have the BK eyebolts still somewhere.... After the move things are a bit everywhere and not all boxes are opened yet... I will check and let you know.
Addict & Guru
Looks like I'm pretty well set thanks to the advice & assistance of several of you, especially Jeff Curtis. Thanks also to Anir, Danny, & Greg.
I still need (4) eye bolts, (8) snap connectors & (2) red Sparco dual anti-sub belts which I'll order from OG, unless someone wants to unload theirs.
