944 Fuel Cell Installation - Revisited
Hey All;
The install progresses. I can basically say to everyone that this project can't be done. I could never have afforded to pay me to do all this work. I'll be in it for under $1200 in parts (this includes a dry break system!), but the labor would be extreme. The Kokeln / Worldwide Motorsports cell at $1800 is still monumentally expensive, but looks a lot better now. The only other solution is to buy a smaller cell, or two small cells and then you have a lot of custom plumbing to do. If anyone is interested in my research, let me know and I'll share what I've learned.
Clue 1 that something is afoot. Look Closely!
Looking behind Door #1 reveals...
Yes, as you might note, the gas door and the pocket had to be recontoured to fit back there.
Now it get's deep!
The frame has been sectioned out and boxed to gain width for the cell. The preceeding 1.75" tube saddled on top of the OE frame rail has been bolstered by another one sectioned in right below it to create a smaller but hopefully stronger assembly. The original side inner quarter panel (the one with the jack point) was removed and the beveled panel you see is a fabricated replacment that sits 2.5" outward from the old (it runs directly veritcal from the quarter seam). I moved into the wheelwell 1.5" and even with that there is a scant 1.2" clearance to the trans.
Here's the goods!
Everything that could possibly be in the way was... like the pre-existing panel-holding square-tube crossmember that had to be modded to clear the filler. The SS fuel line is awaiting metric-to-AN adapters and enough correctly sized Adel clamps, and the vent (capped blue port / steel to rubber return laying in front of the cell) is also awaiting fittings.
Determined to salvage the existing interior panels.
What's a little more fabricating? Just a little welding and filing! The original hole for the fuel hose up front still needs welding in.
Relocated!
The fuel pump used to be on the lower inner wheelhousing. I moved bracket and all to the back of the "can."
That's enough for now!
Now it get's deep!
Here's the goods!
Relocated!
Um...no...
Lack of a personal fortune! Kokeln = $1800-2500 (depending on vender I guess). Then you gotta get it in. JAZ = $187. Get it?
As I say, I'm into it for under $1200, and $500 of that easily is the dry break!
Geo -
The gas door move was very last minute. Classic case of Ants-in-the-Pants. I built everything while the stupid female portion of the dry break was on back order. When it arrived I realized there was no way my original plan of running the filler hose would work. Moving the filler pocket was a reluctant and last-minute Plan B.
David -
Sharp eyes, dude! Get off yer duff boy and get one. Yes I built extras. One could go to Tennessee if you get motivated!
David -
Thefu
So now the question that must be asked is: What kind of fuel mileage is everyone seeing on their track cars, and with this size cell, can that get you to the mid-way fueling point in an enduro? I'm not too interested in spending Kokeln type money either. I know this cell is fine for a sprint race, but is it big enough for an enduro?
Originally posted by RedlineMan
David -
David -
Give me a total and where you want the money sent.
Hows that for motivated
Hey Sea;
I can run all day on the OE tank. Ahhh... the joys of having no horsepower! I figure 2 runs per tank with some to spare now that I'm down to 12g.
I know that I could do a double ATL SP110 ($489/10 gallons each) setup, one on each side of the trans. The plumbing would be a bit of work, but it could be done. $1000 for just the cells was out of my budget.
Thefu
Hey Sea;
Hey Sea;
John,
Cool job. Did I miss how many Gals it holds? I was at Nashville Super yesterday, and a guy from Mich had a regular square cell in his 924S on the rear deck, he said the raised CG didn't bother him, I didn't stick around to see how he did. (Only three cars in his class, him a 16Valve Mercedes, a BMW 323.)
I didn't make the race because the water temp maxed, and I guess I didn't bleed it well enough. I quit working on it late Fri, too late to make the race, DRAT!!!!
Originally posted by Bill L Seifert
John,
John,
What kind of race was in Nashville ? something close and I miss it !!!!
Hey Bill;
Mine is a 12g cell, enough for an N/A.
I guess looking at it from the end perspective, raising the CG is not so bad after all. Definitely the lesser of two evils it seems from hindsight. It does SIGNIFICANTLY raise it, but the work necessary to get around that trans makes it more appealing.
The shortest cell I know of in any decent capacity is the ATL SP122A, 22g, at 8.5". It is $600+. If I'd skipped my dry break system, I could have afforded this. It would DEFINITELY been easier to install.
