Hans Advice (not be confused with Hans and Frans)
Originally Posted by fatbillybob
4 shoulderbelt hans specific harness solves all hans pain and improves hans function according to dr. Melvin. Negative is added cost, increased install difficulty, slower driver change over. Pluses increased safety, increased comfort like it isn't even there. When uncontained one of early hans complaints was wing popping out from belts. With the quad 3" shoulder is always on the body. 2" holds hans. So even if hans pops out you are still retained. Everything is improved with full containment seat. I have used this style about 15 years since available after development with schroth and mark weber.
You have any pics of your quad belt setup? Feel free to PM.
I run the Schroth Flex Large as I have a really big neck, but my daughter uses the Hans, but she is pretty tall with a tall torso.
Glad you are OK!!!
Glad you are OK!!!
Like this but I use the one from HMS MotorSports schroth hybrid 8pt uses 3" body 2" hans 2" laps, individual subs
https://www.discoveryparts.com/sparc...rness-set.html
