Clutch suggestions for SP3 car?
Need to replace the clutch in an SP3 car. Running a 968 motor with a 944 S2 transmission. Any suggestions based upon good or bad experiences?
I had the same engine/trans setup in my old NASA GTS3 car and used a SPEC stage 3, 6-puck and lightweight flywheel. Likely overkill as I was able to use the same setup when I went to the LS engine setup.
^^ source of the lightweight flywheel? A 3.0 L lightweight flywheel for a S2 seems to be a tricky find. I have only seen a SPEC model.
I use one of these with the stock disk, plus an S2 harmonic balancer. I added a spacer behind the pilot bearing to keep it in place. Run for one season so far.
https://www.ebay.com/itm/Fidanza-Fly...EAAOSw-pBcZWd8
