Saw 280* oil temp at WGI last week
#32
Another data point similar to the OP’s: my 991.1 Carrera S with PDK would routinely run oil temps in the 265-270 F range at the Glen in the summer. I didn’t have the center radiator either. That car would also go into limp mode at speed in T10 at the Glen with a PDCC fault. Very scary when the computer kills the car’s momentum in the middle of a high-G turn.
#36
I don't have PDCC, so at least that variable is out. But it looks like I'll try short shifting a bit on the straights to see if that keeps the temp down to a reasonable level.
#37
Just to second Charles comments about CSF radiators. They are much superior from thermal capacity then from BEHR and quality is outstanding. For reference points, for my 997: CSF # 3553; CSF # 3551; CSF # 3552
#38
Chris Cervelli
Cervelli Technical Service
#39
To Chris's question above, I installed CSF radiators on my GT4 front 981S .I wouldn't say they were any better at cooling than new OEM products, but at the time, I could buy the CSF for slightly less money than OEM which is why I went that route. They might be better, but I don't think they are 10 degrees better.
#40
I tracked a 991.1 4S for the last two seasons. I'd guess we probably go to the same tracks, and drive at similar ambient temps given our shared location. I've never once seen a 280 oil temp on this car. It didn't have the extra center radiator either. From what I can remember, my car used to run around 200 on the street and 220-240 at the track.
280 seems wild. You might want to get that cooling checked up, just in case.
