Tuning out oversteer w coilovers/springs?
Trying to tune some oversteer out of my 997.2 gt3. It rolls more than I’d like so I don’t want to soften up the rear bar. Wondering if anyone has had luck w adjustable coilovers / different spring rates.
For reference
- stock shocks/springs w 35k miles
- dsc
- rear toe rod, rear upper control arms, tie rod ends all spherical from rss
-2.5 f / -2 r camber, 0 / .1 deg toe f/r
- NT01 245 and 305
- one from hard front, middle rear on bar
- guard diff
For reference
- dsc
- NT01 245 and 305
- guard diff
What track?
For reference
- dsc
- NT01 245 and 305
- guard diff
For reference
- dsc
- NT01 245 and 305
- guard diff
Excellent hint about mid-corner roll coupling
I've got a set of Motion Control 3 way adjustable dampers with springs with only one weekend on them. I'll cut you a good deal. The owner of Motion Control set them up for me. They are for a 997.2 Cup but should work on your car. I'm sure they would help set you up.
Let me know.
Stu
Let me know.
Stu
Thank you for the links and comments - all helpful. To clarify my question, I'm speaking less to 'how do I tune the oversteer out of the stock suspension' and more to 'what real world result did folks get when upgrading to a good motorsport coilover on a 997 track day car'. Hope that makes sense as it's a big investment.
Most notable at Buttonwillow. Bus stop (the entire complex), Riverside, and sweeper are where I feel it most - causing me to lift or be less aggressive than I'd like. Consistently running 1:59.
Re corner entry: Mid-corner and exit. Corner entry car feels good. Mix of mid and high speed as above.
Re roll bars: Roll bars are stock with stock links. As above, 2nd from hard on front and middle on rear. Admittedly I have played less with the bar settings than I should.
Re "Rolls more than I like": This is related to (a) how the car feels in transition (significant body roll during direction change) and (b) a sensation that the car has to roll and plant before it is stable in corners. When I turn in, it feels like the rear needs to roll and squat before there is grip - I'd prefer the car be flatter and not need the squat.
Re Oversteer limits: Oversteer is limiting both trail braking and throttle application - I'm more concerned with the throttle application. I prefer how the car feels on throttle with the diff working so I am generally on light throttle pre-apex. My feeling is that the car should have enough grip to go full throttle much sooner and longer, but the oversteer and roll are sapping my confidence.
Tire pressures are 32/33 hot.
What track?
Corner entry or corner exit? High speed or low speed? What do you mean by "It rolls more than I'd like"? What kind of roll bars? Have you tried stiffening the front bar all the way? What does the oversteer limit - Trail braking or throttle application? What tire pressures are you running?
Sounds like you would benefit from adjustable shocks.
Squat is part of the 911 experience.
You need to do sway bar sweeps to understand what they do re. roll coupling and balance, particularly mid-corner.
Being on-throttle before apex is a big hint that a) your Vmin is too slow and in the wrong place, and b) that you feel better with LSD lockup prior to apex likely because you don't feel confident about the rear of the car.
You would probably benefit from having a pro drive the car and help you with setup.
My 0.02
My 0.02
My 0.02
My 0.02
What's the diff break away set to?
Everything you posted about your setup sounds like it should be understeering everywhere, IMO. Apart from having a Pro hop in the car and do 1 lap to verify what you're feeling -- if it were me, first I'd make the rear bar fully soft just to see if that has any improvement (it doesn't matter what you feel or think about too much or too little roll). Then I'd add a bunch of toe-in on the rear (and make both L/F the same... you're not driving at Lime Rock). Also, put the car on jack stands and give both rear wheels a hard wiggle/shake left/right and see if there's any movement.
Also, is the balance the same throughout the age of the tire? Have you tried fresh tires?
The ride height on a stock 997.2 GT3 isn't adjustable is it? If it is, lower the rear 5mm.
-mike
-mike
my question, ... 'how do I tune the oversteer out of the stock suspension' and .... 'what real world result did folks get when upgrading to a good motorsport coilover on a 997 track day car'.
And yes a true track oriented set of springs/shocks can dramatically alter the behavior of the car on track. Dramatically, as in addition to a stiffer platform you get the ability to also adjust corner weights, rake, and more with adjustable suspensions.
Something tells me you want this car to retain it's daily driver comfort ? It's a tough compromise if you want to go fast.
With stock springs its going to roll. A lot... Plain and simple. It's going to roll enough that your -2º camber may not be enough to stop the tire from rolling on to the sidewall. Have you marked the tires to check the rollover?
But here is a question... and hear me out on this... How do you KNOW it's over-steering?
The 911 is a unique beast. With no weight over the front and most of the weight behind the rear axle you get a very different sensation when turning the car into a corner.
It's all about roll rates and their timing. As you turn in to a corner the front begins to roll and then the rear begins to roll. No different than a FWD GTI or Front Engined/ Rear Drive BMW at this point.
But at some point as the weight transitions, the light front end will complete it's transfer and therefore stop rolling.... while the rear (wait for it) is still transferring weight and still rolling. This is where it's different than a front engine car.
So while the rear is still rolling (taking a set) your brain may think it's over-steering.. but its quite possibly not ! It's just out of phase with the front and finishing it's weight transfer.
