New Tech Article: Track and Racing Brake Pad Owner's Guide
Old 03-27-2019, 04:23 PM
JRitt@essex
Basic Sponsor
JRitt@essex's Avatar
Default New Tech Article: Track and Racing Brake Pad Owner's Guide
Hello Gents,
We just released a new tech article on our blog titled, "Track and Racing Brake Pad Owner's Guide". Please check it out. Thanks!
'09 Carrera 2S, '08 Boxster LE (orange), '91 Acura NSX, Tesla Model 3 Performance, Fiesta ST
Jeff Ritter
Mgr. High Performance Division, Essex Parts Services
Essex Designed AP Racing Radi-CAL Competition Brake Kits & 2-piece J Hook Discs
Ferodo Racing Brake Pads
Spiegler Stainless Steel Brake Lines
704-824-6030
jeff.ritter@essexparts.com
Old 03-27-2019, 09:19 PM
Steve113
Steve113's Avatar
Nice explanations - well done
Old 03-29-2019, 07:46 AM
grrrmonster
grrrmonster's Avatar
Some very good tips in there. Thank you
Old 03-29-2019, 04:17 PM
gbuff
gbuff's Avatar
Good stuff--my inners wear faster than the outers (stock calipers on a Mini) so I order my pads with all outer backing plates (the ones without the ears for the sensor wire) and/or grind the ears off so I can swap them inside/outside.
Also did run into some severe chunking with a well-known brand years ago; changed brands and now all good
Gary
Old 03-29-2019, 07:09 PM
ProCoach
Basic Site Sponsor
ProCoach's Avatar
Received 2,793 Likes on 1,651 Posts
Thank you for posting!
Old 03-29-2019, 10:19 PM
ExMB
ExMB's Avatar
Received 1,310 Likes on 796 Posts
Great article. Thank You Jeff
Old 03-30-2019, 11:48 AM
SWK6Cup
SWK6Cup's Avatar
wow- some very useful and helpful information- thank you!
Old 04-01-2019, 02:10 AM
jayzbird
jayzbird's Avatar
Glad to hear they condone swapping pad locations. Tip: put numbers 1-4 on the back of each pad so you can track what positions they’ve been in.
Old 04-01-2019, 03:35 PM
JRitt@essex
Basic Sponsor
No worries gents. Glad you all enjoyed it!
Yes! I have done that, and suggested others doing that as well using DFI (Driver Front Inner) or PRO (Passenger Rear Outer). I should put that in the article. Thanks for the reminder!
Old 04-01-2019, 04:51 PM
steved0x
steved0x's Avatar
Is there a recommended rotation pattern for brake pads or just swap inner and and outer on the same side periodically?
Old 04-01-2019, 04:59 PM
JRitt@essex
Basic Sponsor
Rotate as needed/demanded. Each track scenario and driving condition is going to be different. A track that has all of its turns in one direction will likely result in a different wear pattern than a track that has a balance of left and right hand turns, so recorded wear should dictate where you put them.
Quick Reply: New Tech Article: Track and Racing Brake Pad Owner's Guide
