Need help with Aim MXP Pre-Calculated Gears for a GT4 CS - Page 2 - Rennlist - Porsche Discussion Forums
Old 03-15-2019, 10:27 PM
ProCoach
Small Business Partner
ProCoach's Avatar
Originally Posted by GT345 View Post
Off hand do you know if it is the rolling circumference 83.12, or the diameter of the wheel 26.81?
It specifically states wheel circumference, not the diameter.
-Peter Krause
www.peterkrause.net
Professional, Private Driver Performance Analysis
Authorized Sales and Support for AiM Sports, VBOX Video, MoTeC, AutoSport Labs, RaceVoice LLC, Apex Pro and Cosworth Electronics
ProCoach is offline
Old 03-15-2019, 11:25 PM
GT345
GT345's Avatar
It surely does... Someone else gave me the wrong info.
Thanks again, will let you know if that did the trick!
GT345 is offline
Old Yesterday, 05:17 PM
Krokodil
Krokodil's Avatar
Your AiM dealer should be able to help you with this after you enter the intermediate ratios.
The ratios I have are: 3.909 2.292 1.654 1.303 1.081 0.881 with 3.25 final drive
The tire companies (depends on the tire you use) have the wheel circumference (this is for the rear wheel). Pirelli 680, IIRC
The default timeout works fine and the ECU RPM channel name should be used. The speed should be set to GPS speed.
Setup for the PDK requires an adjustment when calculating final drive, as there is an intermediate shaft, or Constant Ratio shaft (CR), that creates a second multiplier.
The 2016 Clubsport has CR shaft with a ratio of 1.146, which when multiplied by the R&P ratio of 3.25 yields a final drive of 3.72.
For comparison, the street 2011 Cayman S PDK has the same 1-6 ratios, but has a CR 1.114 and a R&P ratio of 3.090, yielding a final drive of 3.25.
Cheers,
Krokodil is offline
Old Yesterday, 05:58 PM
GT345
GT345's Avatar
Cheers,
Interesting... It is a simple update and I can test it both ways to see which works.
Do you currently use an Aim device with pre calculated gears?
On a side note I found my owners manual for the CS and it did show the gears stated originally by ProCoach, with a FDR of 3.25
GT345 is offline
Old Yesterday, 06:38 PM
Krokodil
Krokodil's Avatar
Interesting on the owners manual. Please post a pic of the page, as I am curious whether the manual states Final Drive or R&P.
The ratios I posted above came from this document: https://clubsport.pcaclubracing.org/...d-April-20.pdf
Here is an extract:
6speed Sport Porsche Doppelkupplung (PDK)
Gear ratios:
1st gear 43/11 i = 3.909
2nd gear 55/24 i = 2.292
3rd gear 43/26 i = 1.654
4th gear 43/33 i = 1.303
5th gear 40/37 i = 1.081
6th gear 37/42 i = 0.881
Reverse gear 39/11 i = 3.545
Constant 47/41 i = 1.146
Ring gear & pinion 39/12 i = 3.250
Krokodil is offline
Old Yesterday, 06:46 PM
GT345
GT345's Avatar
The number I posted about came from this document: https://clubsport.pcaclubracing.org/...d-April-20.pdf
Here is an extract:
Transmission (gearbox/differential lock)
Gear ratios:
I think your right about the R&P and that PDF looks like the same ratios as the manual i was looking at.
Thanks for your input!
GT345 is offline
Old Yesterday, 09:23 PM
ProCoach
ProCoach's Avatar
Cheers,
Thanks. I was using Calc Gear on the CS's that I looked after. Good info.
-Peter Krause
www.peterkrause.net
ProCoach is offline
Contact Us About Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
