Sebring Punt
#182
Ignoring some of the "off the point posts" i found this thread interesting. I run in black at Sebring often and have on occasion taken a pass and gone into turn 7 two abreast. During the PCA Instructor Weekend we practiced going through all the turns two cars next to each other so I'm not uncomfortable doing so. This thread has me question whether it's worth taking the risk. As mentioned, we're there to have fun and we're not racing. Also, I don't buy track insurance so I'm self-insuring my car. In the future, I'm going to decline a point by that would cause me to go into 7 off line.
#183
Turn 7 at Sebring is a perfect breeding ground for trouble. My low-HP Boxster is bright blue and people can see it coming in the rear-view mirror. There is a tendency to assume it is faster that it is...and, often, I will get an early point-by as we approach the braking zone. But it takes me a while to get there and, as I barrel down the inside, now deep in the braking zone, I often wonder if the driver being passed will still honor the point he/she gave. Sebring Roulette.
#184
WRONGLY ACCUSED!
Received 3,275 Likes
#185
I've observed that most good racers use this method most of the time. Of course, this is less relevant for DE and concerns mostly racing but I've often seen it done in the fast DE run groups (black, red) of my local region (CVR) where incidents like seen in the OP would be extremely rare, if not non-existent.
#186
Turn 7 trouble at Sebring
In the ’77 photo, I had gotten alongside Greenwood under braking, but the Corvette moved over to take the turn. I went for the grass to avoid getting hit. I survived and we finished 1st overall.
The other time I got into trouble was in ’75, just 15 minutes before the finish. I caught a slower car which was running right in the middle of the track between 6 and 7. I had driven a total of eight hours and I was tired. I decided to pass on the left, got my nose in, just as he moved left. I went to the grass, tried to manage it, but spun all the way to the Hairpin, luckily headed in the right direction. Sometimes it pays to bail out. We finished 2nd place overall to the factory BMW of Redman, Stuck, Posey and Moffat. Regarding hand signals, few were given in my day and problems between drivers were handled on the track or in the pits right away.
#188
#189
I usually run with friends in black. We run off line and half track to get the experience and know how fast the car can go through and still stick. I moved to Pink for this event because I’ve seen a few people not ready for full course passing running in black throughout the year. The added volume in the Feb event increases the risk of a bad situation. Not sure if it’s an ego thing about wanting to move out of white but a few drivers drive like black has the same passing restrictions. Full course passing with a point by is just that. The only difference between pink and black is supposed to be pace. Nothing wrong with staying in white if you want to pass and be passed in the straights. Weigh the risk and make a choice. Some of us have done that and having people on track with two sets of assumptions is what makes it dangerous.
#192
Received 1,439 Likes
#194
A good trick taught to me by Skippy instructors is to always take inside passes by getting very close beside the passed car. This makes you more visible to them as you fill out their side mirror at all times and they also see your nose much sooner (at a better angle) as you come out ahead. In terms of race-craft, this keeps the passed car pinned to the outside and gives you more options (more track) and the advantage of choosing the timing and the angle of the turn-in that suits you best -- for optimal corner entry, speed, and exit. He can only turn in AFTER you do. Finally, even if the passed car decides to move into you (or doesn't see you there), there is only a small distance before he finds out that you are there -- the contact will be a mere a brush instead of a full on hit if you were two car widths away inside the turn. Much safer for both parties.
Is it just a judgement call based on the corner / driver / speed? Any rules of thumb you use?
#195
Rule of thumb- Its DE give as much as you can . Fill his mirrors before the pass so he knows you are there and then give him as much room as you can without upsetting your car to much.Give hime a nice peek in his left side mirror then right and then pass, Again its DE if you are slower in a turn because you were more off line or checked your speed a littlie anticipating the worst, him moving over who cares. The checker means session over not that there will be trophy ,champagne and sponsors at the finish
All of this might doesn't apply to PL situation that was RED Mist/Really bad judgement on the passing car
