Predictions for the SCCA National championship RunOffs Sonoma Raceway 2018
#31
Regarding the weight, this was the ideal track for Porsche’s when compared to the other cars, where as VIR will be a much different story next year. Oh well, that’s club racing. Happy to be flying the Porsche flag at the end of the day!
#32
Basic Site Sponsor
Basic Site Sponsor
Received 2,799 Likes
Congrats! See you at VIR!
#33
I'm so happy to put my 5th Runoffs in a row is behind me. It was the most painful worst 2 races I have ever had period. I had more fun at Indy Runoffs chasing cars then having my motor blow up. At Sonoma My car was unusually slow and lack grip all week. Both T1 and T2 were at the same time of day and both days ambient temp were near the same. I started on new tires in both races and exactly 30 miles into the race I would get this massive rubber pick-up in T5 and T9 and I was on the standard line and my car would feel like I was doing 4 wheel drifts pitching all over the place. It was so undriveable in T1 I quit the racing thinking there must be something wrong, a broken swaybar link or something. The car was fine. In T2 I finished the race but I could have lapped faster in my diesel pickup truck! I had to tiptoe though 10 to stay off that wall and brake super early for T11. Aggressively turning out of T11 & T7 were my tire cleaning turns. It was painful! WFT! I have never experienced anything like that.
#34
That is really odd.. our cars are similar in many ways, and i know, even when its a complete mess, i can put on good tires and at least have fun. can you give me a link of your video, or send me a drop box link to see it? maybe there is something i can see. too much pressure? i know you have a lot of weight, but ive taking folks for rides in my car many times and only cost me a second or two.
do you change the weight between T1 and T2? I forgot , you have the C4 Zo6 405hp model, no?
#35
Coming from the Midwest and having raced against Andrew A a number of times, I was very impressed by Kip in the GT2 race. The same with Olson in the T1 race. Those NSX’s were quick.
I’m out here racing in T2 in a 2003 Porsche CS. Qualified on pole by 0.2 seconds. Should be a fun race.
Cheers
Mark
#36
SCCA T2 GCR
>> I don't know much about T2
See SCCA GCR info below
In case you can't read it, here are the notes from the 996 GCR entry above:
Ducting for coolers is free, provided it doesn’t change size and/or shape of factory body panels.
Springs up to 800#/in front and 1000 #/in rear allowed.
Ducting of air to rotors is allowed. Tender springs 60-60-25, and spring holders ZT-1-X002A01 allowed.
Removal of rotor dust shields is allowed.
Sway bar size and configuration is free
Spoilers & bumper/ airdams are free provided they do not exceed the max. body width by any amount and/ or the max. body length by more than 1”.
Rear wings may be no higher than the roofline.
Camber adjustment slots may be elongated.
Porsche Motorsport front and rear control arms allowed.
Cold air intake allowed.
There are far more mods allowed to all car in T2. If you are interested in the full set of rules, you can DL the latest GCR here and navigate to the T2 section on page 625.
Porsche spec lines start on pg 639. There are 8 spec lines covering all 996/997 and the 3.4L Caymans. The 3.6-3.8L Caymans run in T1.
https://www.scca.com/pages/cars-and-rules
https://www.scca.com/downloads/42451-gcr-october-2018
#37
More notes on T2 for those interested....
SCCA T2
3.4L / 3.6L (update/backdate '98-'05) 3050lbs
Chassis/Suspension
- 18 x 8.5" x 11" wheels, 255/315 tires
- A maximum of 3.0 degrees of negative chamber is allowed. Camber adjustment slots may be elongated.
- minimum ride height is 3.75” inches measured at lowest part of rocker not including seam.
- Ride height to be measured without driver at the lowest point of the rocker, but not to include welded seams or fasteners.
- Spherical bearings/bushings are not permitted in T2-T4 except for adjustable toe links (996 allowed PMNA Control arms)
- All T2 cars are allowed to replace OEM upper and lower control arm bushings with polyurethane or delrin bushings.
- Porsche Motorsport front and rear control arms allowed (note this says Motorsport, not just GT3)
- Spoilers & bumper/air dams are free provided they do not exceed max. body width at all or the max. body length by more than 1” (Aerokit / GT3 bumper ok)
- Rear wings may be no higher than the roofline.
- Air jacks are permitted
- Ballast may be added as required, to meet weight, provided it is securely mounted within the bodywork and serves no other purpose.
- Batteries must be of similar amp/hour capacity , size and within 10% of OEM weight
- Stock replacement brake rotors, provided they are the exact equivalent of the stock rotors.
Engine/Drivetrain
- Blueprinting and balancing is allowed
- .010" overbore is ok w/ a 20 lb penalty
- Any oil cooler(s) is permitted
- may replace the catalytic converter(s) with a pipe of same diameter inlet and outlet as the converter it is replacing.
- it is permitted to modify the stock header only to replace the catalytic converter
- may replace any part of the exhaust system beyond the catalytic converter
- The engine management computer or ECU may be altered within the original housing.
- air conditioning system may be removed
- Any transmission cooler(s) is permitted
- permitted a limited-slip differential
- Any clutch disc and pressure plate of OEM diameter may be used
- A dual mass flywheel may change to a single mass flywheel that is no lighter than 5% of OEM weight.
SCCA T2
Chassis/Suspension
Engine/Drivetrain
#38
Good to know, thanks for the cliff notes!
#39
SCCA T2
Chassis/Suspension
Engine/Drivetrain
SCCA T2
Chassis/Suspension
Engine/Drivetrain
thanks
#41
#44
Impressive times for 290rwhp and 3000lbs .... How did Boden's car stack up, after all, he has a 997-2 and the c5 and c6 vets? (still hard to believe they can class them in T2.. but i guess weight equalizes)
