FS: 944 Early Reinforced Steel Lower A Arms
T&T Racing , Yesterday 03:50 PM
Purchase the robust reinforced steel lower A arms with the trick Racers Edge monoball cartridges. There is no flexing of the front suspension with solid bushings and the suspension is totally compliant with driver input, no hysteris. The ball joint is easy to replace, just remove 3 bolts and install new one. They are compatible for installing the popular Tarett sway bar and even some Porsche sway bars.
The Racer Edge monorail cartridges retail price is $627.
For this deal the price is $279 plus shipping and the most robust lower A arms available. And as a bonus, the routine replacement of the bolt joint is removing 3 bolts and inserting the new bolt.
Just go to HPDE or racing event and not worry about your front lower control arms.
