F-Stock Boxster Build
#76
Working on integrating a rain light. I chose the CarTec Multi light for the hazard and rain modes. I decided to tuck it under the rear spoiler and fabricated (3D printed) a custom mount to fit the space perfectly. The Cartec bolts to the mount and the mount bolts to the spoiler with a couple of M6 bolts hidden in the spoiler body. Still a work in progress...Trim removed.
#79
Exhaust cutouts installed in catless mid pipe.
Vac lines not yet run, but I'm going to use a small aux vac pump in trunk rather than engine vacuum.
Vac lines will poke right from cutouts up into trunk. Just a couple of inches.
#81
#85
First test of the cutouts complete. Here is a video:
At the end are some pics of the setup.
I still have some work to do. The vac pump has a cutoff switch at 15" of Hg and the cutouts need about 20.
They are only 60-80% open.
I will either find a 20" vac switch or just eliminate the pressure switch and use a turn off delay relay to just run the pump for 10sec on actuation.
#87
After 67s of track time this season looks like I have an intermix issue and need a new engine.
The easiest solution is a like for like 3.2 'race' rebuild (e.g., from RND/LN).
If I want to step out of F stock (as long as the result is classable),
what are the recommended options?
Thinking 996 3.4 or 3.6; but unclear who will rebuild the 3.2 with increased displacement.
Thoughts? Comments? Sources?
DB
DB
#90
The easiest solution is to buy a used replacement motor with the correct displacement Any odd-ball track car that doesn't fit into a popular race class is very hard to sell. Why did the current engine fail?
