F-Stock Boxster Build
Old 11-29-2018, 04:57 PM
  #46
dbbarron
dbbarron's Avatar
Aerocatch brand hood fastener install with custom 3D printed brackets done!
Old 12-04-2018, 05:50 PM
  #47
dbbarron
dbbarron's Avatar
PC680 battery added.
Old 12-05-2018, 02:22 PM
  #48
BFT3.2
BFT3.2's Avatar
For what it's worth, that little battery(fully charged) was "just" able to start my car last night who's every bone was no more then 25 degrees with 5w-50 in the sump. Not recommended but pretty impressive.
Old 12-05-2018, 05:35 PM
  #49
dbbarron
dbbarron's Avatar
Wheels ready for custom powdercoat:
Old 12-07-2018, 11:35 PM
  #50
dbbarron
dbbarron's Avatar
Powder coat done!
Old 12-10-2018, 05:22 PM
  #51
Larrypcar
Larrypcar's Avatar
Welcome to F-stock, I have a Deman f- stock as well. Well built and strong cars. Good luck see you out there.
Old 12-10-2018, 05:25 PM
  #52
Larrypcar
Larrypcar's Avatar
I noticed no cool suit setup. I can speak from experience these cars get very hot inside its a most.
Old 12-11-2018, 08:38 AM
  #53
dbbarron
dbbarron's Avatar
Thx. That is in process. Where did you run the lines from the frunk to the cabin?
Old 12-11-2018, 09:14 AM
  #54
Deadeye
Deadeye's Avatar
Nice looking wheels! Make sure you rough up the inner lip where the tire bead makes contact to reduce tire slip under hard braking
Old 12-11-2018, 02:43 PM
  #55
Larrypcar
Larrypcar's Avatar
Deman ran his from front trunk through wall, zip tied to roll bars along side of door to around the knee area. Next time I am at the car I will take pictures for you.
Old 12-11-2018, 02:58 PM
  #56
dbbarron
dbbarron's Avatar
From the frunk I assume he went through the 'first' firewall on the passenger side where there are some big openings; and then through the grommet behind the battery. Correct? Would love to see some pics.
Old 12-11-2018, 03:42 PM
  #57
Larrypcar
Larrypcar's Avatar
Actually no he went in from the driver side.I will send pictures soon
Old 12-11-2018, 04:39 PM
  #58
Larrypcar
Larrypcar's Avatar
this is from inside , I will get one from the trunk soon
Old 12-16-2018, 12:26 PM
  #59
dbbarron
dbbarron's Avatar
Ben's shifter installed.
Main power cutoff moved to main switch panel (was on shifter).
Can someone recommend a switch and guard for the main power cutoff. The guard I'm using seems to want to snap down too easily.
Old 12-16-2018, 06:45 PM
  #60
lmnsblu355
lmnsblu355's Avatar
If i were you, i would move that fire extinguisher button closer to the driver, like where your rear wiper switch is in the pic. God forbid you need it, you don't want to have stretch for it.
Quick Reply: F-Stock Boxster Build
