Airbag to engine CU signal
I am minimizing the wiring harness in an '08 Cayman S being prep'ed for Spec Cayman. Airbags are out along with their harness. There's a signal wire from the airbag control unti to the engine DME, and I'm curious to know how it gets used. I believe it lets the airbag CU signal that a crash has happened. Anyone happen to know what the normal and post-crash states of this signal wire are? Obviously hoping I can simply delete it, but if it needs to be grounded or +12, good to know.
km, thanks.
