have R7's changed? disturbing grooving
Ah the old wire of death. Seen it on R7s and slicks many many times. One time at Daytona it took out the rear of a 996tt including the intercooler, bumper, and took paint off most of the rear fender. After much hassle and "we have never seen this before" they graciously gave us a new tire. Funny after the third or fourth claim with Hoosier with the same person saying they never saw it before I reminded them that he was the same guy I spoke to the last few times. Then quick deny deny deny but will replace this time.
I can ABSOLUTELY assure you that fender interference is not a factor. and I get grooves and cracks on all 8 tire edges and am certainly not having interference on all 8 tire edges.
I agree with you that the tires should be worn up to the edge of the sidewall writing. if you notice it is worn that far in the pictures of the tires that are "done." the picture you marked up shows an edge that was an interior edge and had just been flipped on rim, but has not been run yet. so that's a crack that opened on the first heat cycle and will become grooves once it's run on the outside edge.
as for pressures. for the first heat cycle of the day, I leave the pits at 30 cold. for all remaining, I run 30 hot. as for overpressure, hoosier recommends more like 36-38 depending upon track. most of the corvette community run 28 hot, but since my blow out last year, I've been running a little more pressure (30 hot) because it's closer to what hoosier wants me to run, so I figure it gives me 2 psi of insurance against what I had when I ran 28 hot.
Wrong.
...and probably wrong.
Mark have you actually run any 2018 spring/summer production R7s?
I have a stack of tires run at various tracks (friction) with careful attention to pressures and alignment (often daily). Most are showing varying degrees of the same issue, consistent with the OP's experience.
Originally Posted by jdistefa
Wrong.
Wrong.
Wrong.
Wrong.
Wrong.
Wrong.
wow, here you go a little proof too. funny, how fake news is so common now! and guess what. buying a new set for the runnoffs too!
what the heck is that? the first picture looks like he ran into a wire fence and picked up a dagger. thats actually coming OUT of the tire??????.... but this one is coming from where, the bead area? never heard of this!
I had it happen on the inner sidewall, I didn't see it but I heard it, but not before it cut the dust boot off of my damper. I have had this happen twice, but only on tires that were remounted.
Wrong.
Wrong.
Wrong.
It might solve these issues too.
Best!
30 is too low on a corvette. The tire seems to grip ok but It picks up too much heat. Having used lots of sets of Hoosiers on a C7 Z06, 36-38 is the appropriate range. It will feel a bit looser at first but the tire manages heat from a heavy car much better and therefore is faster through a full session - much faster at the end.
Best!
Thanks for input. I agree on a C7. my C5 is 3100 with fuel and me. What I find is that most C5 guys are running 28 hot, hence my 30-31 hot for a insurance.
I've had a similar wear pattern on my R7s. Rechecked camber (front -3.0 and rear -2.0) and toe (front=0 & rear=0) which is my standard setup for the last couple years. I have been starting with slight lower tire pressures, and I figured it was that combined with pushing to hard before they came up to temp and pressures.
yup, my alignment is almost the same.
From the fastest and best wearing folks out there, the wear patterns usually end up just at the nubs. its not that they are a formal indicator, its one we use. kind of like the oak tree out of the corkscrew.. aim for it, and usally it will give you a good line . if we could see the inner part of the tires, i would bet that the "nubs" are being hit. and maybe further. i have a lot of fender cam video showing some good tire action ,and it clearly shows that the tire rolls on to this section of the tire. i know if i run near 40lbs (ive forgot to air down a couple of times) the car feels like it is on ice skates.
