Tire wear questions for the experts
Tire is a Hoosier R7 on a Miata running 4* camber. I'm having tire wear as shown below and I just wanted to get some opinions on why it is wearing as such. There is a stripe on the left 1/3 on the center section that exhibits the most amount of wear.
Left front tire (left is outside)
2400 lbs Miata
4* camber
38 psi
2400 lbs Miata
4* camber
38 psi
You listed 4˚ of camber
Did you mean -4˚ of camber.
Negative is when the top of the tire is tilted in.
Positive is tilted out
Positive would explain the wear.
Presuming you meant negative 4˚, you did not list your toe.
There are several variables in alignment and suspension/steering set up that can cause or mimic camber wear; especially with a tire with no sipes to give more clues.
Excessive toe in or out is one of them.
38 psi - Hot or Cold?
Post a picture showing the top of the tire at a horizontal angle looking at the grooves.
That will show us if the tire is wearing flat or not.
Not an expert but -4 is a boatload of camber--if anything the inside of the tire would show more wear, not the outside. As stated, I think you've got other issues at play here.
Gary
Gary
What are the rears doing?
the real question that im surprised no one asked, is what is your toe setting... too much toe in, only a little, can show this kind of wear too. especially the fact that you have 4 degrees camber (a lot) and you are still wearing outside 1/3rd.
24" front of contact point on tire, vs rear? so, if its toe'ed out, by 1/8", that a little much, but would show itselft by inside edge wear , not outside. your pressure can defintely be apart of it. optimal pressures by most of the spec miata guys are in the lower 30s. (32-34psi) that is substantial wear and its very surprising considering the high camber, but too high of spring rate, or compression, could also cause this
