Bittting the bullet and buying slicks for the runoffs. Suggestions for size & Brand?
#46
Mark, I agree with this. Regardless of the size of the time handicap or whether it comes from the tires, the car, or the driver, the most important thing is to have someone to race with and to have fun. Perhaps I’ve put too large of a focus on my car being capable of winning (with a top driver, not necessarily me), since that was the promise Skip Barber made about all of their cars. This thread reminded me that even that’s not that important. Some of the most fun and most satisfying races I’ve had have been when dicing it out with a group in the middle of the pack.
I’ve raced in Skip Barber series since 2009 (50+ race weekends, couple of wins and a few podiums) and only started PCA SPB last year.
Good luck in your nationals with whatever tires you choose! I’d still go for broke and get the stickiest ones allowed. It’s the nationals!
#47
DH's better then anything else for your car . Really fast as stickers ,falls off after 1or 2 heat cycles but consistent. depends how long heat cycle is . I can qualify with good times on the stickers and then run the 30 min race at same times . Cant get those times after that though . Maybe 1-2 seconds off sticker times after the 1-2 heat cycles
I don't run them after 3-4 heat cycles even to practice . Just my thing I always want the fastest times I am way to competitive with myself
#48
thanks
Mark
#50
Michelin delivers the quickest lap.
As Steve said, the Pirelli may deliver the quickest race in your car.
Good luck, Mark
Good luck, Mark
#51
question.. i havent spoken to tony, but he seems to put a lot of his clients on the Yoks.. wonder if here is a draw back. a 3-4th place car in our last race, ran some blistering laps for his HP/weight on the yoks (pictured in the thread)..... in the larger size, I wonder if they will work and if they will work better. im going to pull up the TC design BMW lap times and see if how consistent the laps were. i think he was in a 1:34 range at laguna. if the times didnt degrade , that might be a sign that they are working. I also dont want to take any unnecessary chances on a tire that fails because my car is heavier.
thanks for the feedback
Thanks for the info... leaning toward the pirellis.. now have to compare the price and to see how long vs the pirellis , they will last.
#52
Any help from others here? what about sizes. whats the size that fits on the 11 x18" rim the best? 30 series from Michelin? will that fit on a 10" rim too?
30 x65 x18 on an 11? and a 27 x65x18" on a 10" rim?
Ive tried the pirelli 305x645s for the front, which are a tad small on the 10" rim. I think I'm narrowing this down to the DH Pirelli or the Michelin mediums."8"s
the slightly larger tire for the rear is not available. all they have are 680s, which are a very tall 27" diameter
yoks are a possibility too. but leaning toward the Michelin as the cost seems to be good, but just unsure of the sizing
#53
I've seen some guys in Corvettes that haven't been any faster on DH than A6 (a few years back). I draw that correlation due to relative engine placement. They without a doubt make more grip than A's though. Compressed the springs on my car, which were set up for A6 to the point I thought a damper had failed it was bottoming out so bad. Shipped rears off for rebuild between back to back weekends and everything. Nothing was wrong with the dampers, just not enough spring/damping to begin with.
Practice on scrubs, check forecast, pick the best conditions qualy to sticker up. (I think there are multiple qualy sessions?) Scrub them in and let them sit overnight. 1st and 2nd heat cycle are golden, 3-5 drops off a bit and then anywhere within 1-1.5 seconds take a a lot of bravery and risk after that.
Since you are familiar with aged DH scrubs, use that familiarity to your advantage. It will probably be a bit better because the slicks from new will have the same number and type of HC on each corner. You never know buying used. But the places will not be won at the beginning of the race most likely. It will be as they are falling off. Your familiarity with the behavior of the DH will give you more confidence on where and how much to push. On a new brand, this will all be new and word of mouth instead of feel.
Depending on the times around you, you may even be better off qualifying on scrubs and saving the full life of the new tire for the race. If you only pick up 1 spot by qualifying on stickers why not just beat that guy with patience? Make him drive his tires off. I'm still assuming the multiple qualifying format.
#54
#55
Any help from the racers here with sizing? i need to make a decision in the next couple of weeks . again, i have 10s and 11s. and wonder what sizes to get in the Michelin if i go that route. the pirellis are a little small for the rears on 11s, and i cant use the tall 315x680s for the rear. the michellines have a size that looks like it will work, 30x65x18 for the rear and 27x65x18 for the front, but dont know for sure if that is best. (currently have been using 315x30x18 hoosiers up to this point on all 4 corners, with 295x30s on the fronts sometimes)
thanks
Mk
thanks
Mk
#56
I really could use the input from those that have gone back and forth between hoosier A7s (or other fast DOTs) and slicks.
coming down to crunch time with only near 4 weeks left to make a decision.. in talking to a REAL fast TCdesign Bmw driver whom runs the yoko slicks, he said that they are not better for an all out fast lap, in fact, the A7s are faster in their first heat cycle lap, but the yokes are better from lap 6 onward and usually are very good for 6 heat cycles..... sounds like , with their super hard sidewalls and me having no experience with them, the A7s might still be the better choice. HOWEVER, isnt there a tire that is constantly faster than a hoosier from day 1? sounds like its narrowing down to the DH pirelli, and the Michellins. has anyone slapped on a set of these vs hoosiers and found a full second? I knew the A7s were good, but didnt think that they were that close to the slicks available. i would lean toward the DH if the tire sizes were a little larger to fit my car (the proper width tires seem to be too tall) but,there is talk that they are not even that much faster than the A7s. the A7s are a lot less expensive and might just do that , since it doest sound like there is any magic bullet like i was looking for. thoughts?
#57
Ive just ordered the Michelins. I've heard fantastic things about them. hope they have a little more stick than the Hoosiers. the local dealer is going to give me a set of free take offs for the first sessions and then lll qual and race on the new set. 2 weeks away!!!!
#58
Basic Site Sponsor
Basic Site Sponsor
Received 2,836 Likes
Sure would test first... I'd want to know the extent of the balance change, want to get temps and pressures optimized. Not a good idea to go in a completely different direction than you have data and experience with for the race, AT the race...
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#59
#60
im hoping the main difference is that they are FASTER!
