oil change interval after track days
I have a 2017 BMW M2 and do 3-4 track days per year, no modifications. There are a ton of opinions out there about changing oil after track days, etc. Any recommendations from BMW owners or Porsche owners with similar track day experience?
Thanks, LED
Thanks, LED
Oil deteriorates more for a car driven only in short distance constantly in stop and go traffic than those that are driven on the track. Yes, a track car will encounter higher temperature, but that will not necessarily shorten the life of the motor oil if its synthetic. In fact the higher temperature gives you a cleaner oil because less carbon buildup and less oil breakdown.
Jesus Jimenez (01-14-2024)
WRONGLY ACCUSED!
Received 3,242 Likes
Your race shop or dealership will disagree with these answers!
I use to be paranoid and changed my oil after every 2 events (sometimes after every event). That was until I discovered used oil analysis. After 4 events and after 7 events, used oil analysis showed that my oil still had plenty of additive left, and the oil could go longer. I now change my oil after every 8 to 10 events.
additive is not the only concern. With drastic multiweight oils such as 0w-40 or 5w-50, there is a great potential for shear or viscosity breakdown. Especially with M96/M97 engines, this drop in viscosity can be a killer. Oil analysis is great, but I just change oil after ever 2 events (5 to 6 days). I'm also switching to xp9, which is designed for tracking, but does not have a long drain interval
Running a car on the race track does not "harm" the oil...In fact it's much easier on oil than stop and go driving and short trips....We can go 15-20 hours on high quality oil in the 996 cup and all my other race cars...UOA's confirm this and we have tested oil for well over a decade...Just keep the level topped off. People feel some kind of weird "guilt" when they take their baby on the track...Makes them feel better if they change their oil afterwards....The car will not know the difference and you are likley wasting a lot of money (and time) dumping costly synthetic oil...Just run it out to your normal oil change interval...Unless of course your car is out of tune, running rich, has fuel dilution, etc...You should be looking at diff lube more closely...We change the transaxle/diff fluid after 4-5 hours...Hot rack and LSD does shear the fluid.
If you only run a few events a year I'd just change it every 5k, half of the BMW recommended interval for M cars now. That's what I do with my 17 M2. For this car I would get aftermarket camber plates and upgraded brake pads/fluid also.
Agree with 5k unless you're running a lot of events. I used to do 5k/6-8 days on a E92 M3.
