SCCA or NASA Car class?
Conversation came up about car classes in SCCA and NASA.... actually, in general.
1999 996 C2 with a 3.4 to 3.8l conversion and complete solid end suspension running on R-comps.
The statement that I'd like to refute is "Your car won't class out anywhere. It's a track ****."
Somewhere in the 380hp range, weight of 2800 dry or so.
NASA has power to weight classes based on your average hp over the top of the power band and your weight with driver and fuel. You are likely in the 8-1 class st/tt-2. There are some modifications to the ratio for running smaller tires or having a sequential, but not many of them seem likely to apply to you.
Can't say about SCCA.
For SCCA autocross it would fall into XP, though you'd have to input wheel and tire size into the minimum weight calculations to see if you're legal. I think you're actually a couple hundred pounds too heavy.
So yeah, the statement is incorrect. Your car falls into multiple classes for multiple governing bodies.
Basic Site Sponsor
Basic Site Sponsor
Received 2,797 Likes
In SCCA Road Racing, the 996 fits in two classes, GT2 (which is a Cup car class) and T1 (which may or may not allow the engine swap, you'd need to look at the rules).
There are many cars in SCCA that are not prepared to the limit of the rules for the class, but because they meet the basics (make/model/year/engine size/wheel and tire size/weight) for the class, and meet the safety regulations (cage, seat, fire extinguisher, harnesses, etc), they can run.
SCCA Road Racing classes are much tighter and more restrictive than NASA. GTS and ST in NASA are probably your best bet.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
SCCA I've found is a bit more difficult to class non-stock Porsches. The few times I've run SCCA, I've run in the T1 class as Peter mentioned, though it was less than ideal. Some SCCA regions have begun experimenting with bracket racing, which I've also tried and found to be pretty fun/competitive, and more open in terms of car compliance/classing.
Peter
I would take the suggestions here on class options, and see what the attendance in your regional areas look like. I’d also look at qualifying times and see how that compares to what you run. I ran st2 in a supercharged s2000 for a few years. It was fun, but the corvettes dominate there, especially w longer tracks. GTS seems to be a revolving door of class changes, and a lot of folks have gotten frustrated and moved to ST. ITE ehh catch all.
i think st2 or t1 despite vetts is your best bet, but t again check past event attendance and results!
