SRF mixed with Endless ?
My shop screwed up and topped off my Endless brake fluid with Castrol SRF. (less than 2 oz.)
I know Castrol is not to be mixed with anything else.
After consulting the Castrol website I see that it now says mixing is possible but not preferred. Do I need to worry about this at all?
- It is miscible with all conventional fluids meeting the US Federal Standards FMVSS 116 DOT 3, DOT 4 and DOT 5.1, ISO 4925 and current SAE J1703. This means that changing the brake system to Castrol SRF is easy. Drain and flush out the conventional brake fluid with Castrol SRF then top up the system with Castrol React SRF Racing. Although Castrol React SRF Racing is miscible with conventional brake fluids, topping up Castrol React SRF Racing with conventional brake fluids will reduce the benefits of the product.
Basic Site Sponsor
Basic Site Sponsor
Received 2,833 Likes
Ummm, no. Not good.
I think you should be fine. Endless fluid has a lower wet boiling point than than SRF. They are both DOT 4. Why would SRF degrade performance of the Endless?
If you had SRF in already, then topping off with something else would degrade the performance of the SRF but you are in the opposite situation.
But if you want the best protection, flush the entire system with SRF.
Location: On a pygmy pony over by the dental floss bush
Thanks for the reply okie. Your findings support my own. This is not as dire a situation as I was led to believe. Someone suggested there was some serious chemical incompatibility which would require a complete flush.
I also change fluid enough that I'm not concerned. I run enough Endless through my brake system that the SRF will be flushed out soon enough anyway.
Here is one tidbit that may or may not be related to your situation.
My clutch uses the same brake fluid reservoir. When I had the shop switch to SRF they forgot to do the clutch which had the OEM fluid. Needless to say that clutch fluid boiled on track.
I think that Castrol’s warning not to mix even ‘miscible’ fluids is more to do with the potential of degrading braking performance than any risk of chemical incompatibility. Meaning that even a small amount of another brands DOT 4 fluid could lead to markedly decreased performance versus SRF alone.
Are you blaming residual non-SRF fluid in the clutch system for causing boiled fluid in the brakes?
Just curious. My clutch also shares fluid with the brakes and I never bleed it.
-Mike
Basic Site Sponsor
Basic Site Sponsor
I think that Castrols warning not to mix even miscible fluids is more to do with the potential of degrading braking performance than any risk of chemical incompatibility. Meaning that even a small amount of another brands DOT 4 fluid could lead to markedly decreased performance versus SRF alone.
Endless will mix with SRF. 2 oz. is not going to move the needle on wet/dry boiling point. No worries. BTW, Endless RF 650 is good stuff.
Did that cause a problem with the brakes? I can't imagine the clutch fluid between the shared reservoir, clutch master, and clutch slave getting hot enough to boil even under the worst of circumstances.
-Mike
-Mike
I don't think anyone has mentioned that these are 2 different chemicals... Castrol SRF is silicone based, while every other conventional brake fluid is glycol ethylene. Depending on how big your reservoir is would get a turkey baster and just suck most of the fluid out, then replace and bleed.
