SRF mixed with Endless ?
Location: On a pygmy pony over by the dental floss bush
I don't think anyone has mentioned that these are 2 different chemicals... Castrol SRF is silicone based, while every other conventional brake fluid is glycol ethylene. Depending on how big your reservoir is would get a turkey baster and just suck most of the fluid out, then replace and bleed.
https://auto.howstuffworks.com/auto-...ake-fluid2.htm
Here is another:
http://trackdays.ie/best-racing-brake-fluid/
And from Castrol's website, here is their MSDS for SRF:
https://msdspds.castrol.com/ussds/amersdsf.nsf/Files/70C6D277E51311F1802580570052ADD3/$File/11138339.pdf
SRF is a very high performance DOT 4 fluid, but is not silicone based.
EDIT: Note that DOT 5 fluids are always purple to prevent accidental mixing with other non-silicone fluids.
