Just starting with IRacing, Get this Wheel & Pedals.
if you can go VR, I just put the Rift on my sim and its awesome. graphics are not as good as triples but it feels like you are sitting in the car. I run a T500Rs with a sam Maxwell rim , I had him duplicate the steering wheel that was in my spec racer. I also use ECCI pedals, I went with them because you can adjust pedal pressure with springs.
if you go on the iracing forums used wheels and pedals come up often.
I have a very high end system. Tried the Rift setup and was sick within 5 seconds on the track. Way too realistic but I guess my inner ear was missing the physical movement. I was so disappointed because I loved the immersion.
Basic Site Sponsor
Basic Site Sponsor
Received 2,836 Likes
With my triple (even set up well) at my place at VIR, 30-35% of folks felt queasy.
It’s a known phenomena in jet fighter sim training in the military, and you’ve nailed it exactly. Your eyes see motion that your inner ear doesn’t feel.
Also a major problem with the latency common in most motion platforms. Which is why, if you want motion and have that sensitivity, try D-Box.
try eating or putting some ginger in a drink before you get on the sim.
I could never get past it, but I even got sick on Disney rides that projected motion in front of you and bounced you around in a row of seats. I used to take ginger pills before playing games waaaay back, they do work some but once that queasy feeling hits you're done. I wouldn't mind trying a Rift but am 95% sure it won't work for me...
Basic Site Sponsor
Basic Site Sponsor
I know folks who started out with consoles (PlayStation, XBOX), then moved into PC and they did better than folks that went straight to PC. Lack of latency, I suppose.
The quality of the image, a single image and the speed of rendering all improve the odds of people not being adversely affected, in my experience.
Yes, people have acclimated and become less sensitive to motion sickness. But it's all individual reactions. That's why I start everyone on a single screen, static sim.
Boris Said and I both got ill within a few minutes on twin $660K Cruden Hexapods here at VIR over a decade ago. No fun. But neither of us are sensitive in most other simulators.
You don't want the experience of simulated driving getting in your way of the driving, for sure.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Location: On a pygmy pony over by the dental floss bush
The first time I tried Oculus in iRacing I experienced an increased heart rate I assume because my brain was a bit overwhelmed due to the immersive experience, but I just switched to slow deep breathing and after a couple of 15 minutes sessions, all was normal as if watching a monitor. I've worked in the high-fidelity flight simulator business for 30 years, motion simulators with 6 degree-of-freedom 60" stroke motion systems and 180+ degree out the window displays, and generally people are in two camps. The minority of people will always struggle with some sim sickness, most have no problems. I know one past colleague who was in the business for 40+ years and couldn't be in one for more than 5 minutes without getting severe nausea. I never had a problem. A little trick some people use who suffer from the sim sickness nausea, have some cool air blowing directly on your upper body.
The Penguin King
No difference other than floor hinged or hanging, I think. Personal preference. Just need to anchor them securely.
I have to say, I still LOVE my old G27 with the Perfect Pedal upgrade. Still one of the most realistic feels I’ve tried. And I’ve got three or four high end ($1200+) pedal sets lying around. The V3’s are a little soft for my taste.
I have the Oculus setup and for the first few plays I had to go only for a few minutes and then be done for the day. After a few days I didn't have trouble doing sprints, but I still will need to build endurance to use the sim for more than about 90 minutes. The track does matter - things like elevation changes make it harder on your brain.
The three monitor setup should work without the dizziness issues and gives much better resolution provided you have the hardware to support it. But the VR headsets offer 3D simulation and three monitors is still 2D - going to 3D really helps with immersion.
If you are using a rift i would use a fan just to keep you cool, it does get hot.
Agree. 3 monitor set up increases the sense of speed and will help with race craft. Oculus rift will allow you to sense/see the real elevation changes in the circuits. Triple monitors will show elevation changes better then a single monitor but not as good as the Oculus. Wish the resolution were better - but the immersion is great - particularly when you add in simcommander system.
