Coolsuit MOUNTING
Coolsuit MOUNTING
How are folks securing coolsuit container in your car? I am debating between fabricating a box to slide the coolsuit cooler into or just running some straps across the top. I am curious to see how others have approached this?
Thanks in advance
Thanks in advance
Originally Posted by rhargy
Bolted bottom tray with a ratchet strap across the top. Tray keeps it from sliding around and ratchet snugs it all down
I just bought two brackets from the HW store and bolted them to my floor. The ratchet strap is threaded through them and over the box. The tray seemed useless so I did not buy it.
The brackets I bought totaled to less than $5.
Works just fine
Works just fine
Rennlist Hoonigan
which cost no drachmas
I think the Traqgear setup is the nicest. Just make sure that what it mounted to is solid. The cooler filled with ice is not light.
Cool Shirt Mounting Tray
Here's a link to the mounting tray from Cool Shirt FYI. Not inexpensive but quick easy way to get the mounting done if you don't want to fabricate anything.
https://apexperformance.net/product/mounting-tray/
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: info@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist on your next order or mention Rennlist during your phone order.
Visit us on Facebook
ApexPerformance.net
Rennlist Hoonigan
I have the recommended mounting tray and was wondering how people are specifically bolting it into the frunk.
What type of bolts, where did you mount them (i.e., drill the 4 corners of the tray?); washers under the frunk, etc.
If the bolts are under the cooler, how does one insure the bolt head doesn't mess with the cooler bottom.
If there are bolts protruding under the frunk, how does one make sure they are not introducing a ground clearance issue, or just something for something else to get caught up on.
I'm in....
I'm in....
The corners of the Coolshirt tank are rounded. So if you put the bolts through the bottom the of the tray, but in the four corners, then the tank won't interfere.
PS Now that I look at the bottom of the tank, I see it has feet on it. Those would help too.
