What Parts "Time Out" on a DE car?
#31
Thanks for all of the comments. I've gone through the suggestions and started a list.
So how would you prioritize this list?
- Wheel Studs - $160
I'm still using OEM lugs, though they are not the originals - Caliper Stud Nuts- $40
I have studs installed but never thought to replace the nuts - LCA's - $450 each (x4)
- Caliper Rebuild - $120 (assuming the pistons are in good shape)
Did this 2 years ago so I guess it's due - Axles and CV Joints - $600 (x4)
It's a Turbo - Wheel Bearings (x4) - $90 each
- Wheel Carriers AKA "Knuckle" (x4) - $490 each
- LSD - $3000
- Suspension - I don't even want to know. Guessing $5 to $7K.
i would focus on engine items that can fail and destroy an engine.(timing belt, chain, etc)
keep the oil changed as well as other fluids as well as brake pads when time, and you should be good for a long time.
put it this way.. you provide a list, and i can provide equal as many things that are just as important to change that you might not have even thought about.
#32
Step 1) Totally ignore the previous Post.
You have some nice items on your list. Prioritize wear items(wheel bearings), versus fatigue items(uprights). Also LSDs can be rebuilt. And it doesnt cost $3000. Also a good suspension is less than $5-7K. In addition, if you are running on track, dump the 4wd setup. KISS Keep It Simple Stupid....
#33
I could tell you, but you dont want to hear it. These are in most cases aluminum components in the suspension with varying amounts of rubber. Add to that wheel bearings that are the same as Cupcars. Add sticky tires, good suspension, etc etc and when your lap times are coming down then your parts wear and stress is increasing. There is a pretty good list recently in the Cupcar Forum that many DE drivers should look at for 996 997s.
https://rennlist.com/forums/porsche-...arts-last.html
#35
Just found out that my harnesses are expired now. There's another $600 to $800. For a garage kept DE car, doesn't seem to make sense that they would time-out. My OEM seat belts are not timing out. I don't think any club has ever checked them anyhow.
My car has become a BOATT - "bring on another ten thousand".
#36
#38
yep PCA checks belt dates. Mine replaced- it is what it is. ALSO NJMP - Call APEX. Linda. :-) Joe from NASA will be getting back to me regarding their
rules.
rules.
