Has Porsche Changed the Puck Design?
I posted this in the GT3 forum, on second thought it might be better suited here:
https://rennlist.com/forums/991-gt3-...ck-design.html
That sort of language is not appropriate
What the puck?
Would you say you're more pucked in the rear?
Do you even play hockey?
Former Vendor
The 991.2 GT3's are still using the same calipers as the 991.1s and with them ceramic pucks. However, they have made a minute change to the actual puck design as they did from 997 to 991. In an attempt to help prevent initial cracking/chipping, they sacrificed a larger contact area for more tapered edge with a smaller contact area. As these cars have only been out for a very short time, no 991.2 has had much track use to cause a failure yet. That being said, it is conclusive by the failure rate on the 997s and 991s that the ceramic pucks have a propensity to fail on these cars regardless of the design. We will continue installing our titanium piston puck replacements as a preemptive measure on the 991.2s we have coming through the shop. Time will tell as these cars see more and more track time how the new design fairs.
Photos Below Compare 991.1 and 991.2 Piston Pucks Front and Rear
