Lightweight battery - (but sometimes mixed use)
I got a gift cert for an Optima battery (Not Braille, not Deka, not any other brand) lol.
My 996 is primarily track use - meaning, I take it out on the street rarely, but it happens.
My question is this - can the lightweight Optima still power the car for 'normal' use? Meaning, can it run the stereo, lights, or AC? Obviously - these only run when the car is running (like sitting on grid at Sebring in the summer with the AC on).
Will it work, or a recipe for disaster? I'd love to shave some weight where I can.
I had a tiny Battery Tender battery in my 964. For the use you are describing, it was working fine.
At home, the car had to be plugged though. Otherwise, it would ruin out of juice quickly.
I hope it helps
I hope it helps
The battery doesnt power these systems when the car is running, the alternator does. If you want to run the radio with the car off you may dip under the 12volt mark and have some trouble turning it over. AC doesnt work with car off so not an issue.
So the small Odyssey battery is 14 amp hour in capacity, so if you have some 500 watt stereo blasting full volume for 30min, you will kill your battery and not be able to start the car. however, if it just for track use or you could care less about powering stereos and lights with the engine not running, have fun. no downside.
