AiM SoloDL w/CAN connection: does it charge from the main plug?
Hey all,
Quick question - Google is failing me.
Have an AiM SoloDL in the car (just installed it), connected via the CAN connection (not the OBD-II version).
I know it has a battery in it. Does the CAN connection also keep the battery charged and topped off or do I need to plan to recharge it before events?
Thanks!
Thanks!
No. But the CAN cable should have 4 wires - 2 to the CAN and 2 for power. I just add an "add a fuse" to a switched circuit. After that you never need to mess with charging the internal battery.
Basic Site Sponsor
Basic Site Sponsor
Received 2,836 Likes
Rennlist Hoonigan
which cost no drachmas
The Solo DL is the same for CAN or OBDII. The difference is the wiring. If the CAN and power is hooked up properly it will charge from the car.
Watch that the car does not wake the DL up with CAN signals and kill the car battery. This happens on a number of cars now because the CANbus is active even when your not near the car.
Basic Site Sponsor
Basic Site Sponsor
While it is possible for the fully charged Solo DL to work with car information but not power, it is not possible to charge or run a SmartyCam in addition to the Solo DL.
Also, for most cars, the normal (J1979) OBDII port is required to have battery power supplied all the time. The Solo DL OBDII cable does receive power from that plug.
Cool thanks.
Somewhere along the way (my car has a very LONG story behind it) someone installed an AiM system. I found the connector hidden under the dash this last weekend.
I have no idea if, whoever wired it in, opted to also wire the (+) and (-) in.
Is there a way to tell by going through menus or something on the SoloDL itself to see if it's running off of battery or off of external power?
Rennlist Hoonigan
Cool thanks.
The power and CAN hookup on the DL cable are close together. Blue and white are CAN. Red and black are power and ground.
Basic Site Sponsor
Basic Site Sponsor
That's what is so nice about the Solo DL/SmartyCam combo. Red=12V, Black=Ground and when the switched power comes on, everything comes on, when it turns off, all of it stays on for a few minutes on internal batteries and then it shuts off.
As Matt points out, on the latest cars (generally 2013>), CAN can "wake them."
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Originally Posted by OmniGLH
Yeah... so the AiM wiring done on my car (previous owner?) definitely did NOT include power SoloDL went dead after 3 sessions yesterday. Damn!
Now I have to figure out where they terminated the cable and wire up the (+) and (-).
A little thing that plugs into a spot in a fuse panel but lets you add a 2nd circuit.
Ref: https://www.parts-express.com/littel...m_campaign=pla
Basic Site Sponsor
Basic Site Sponsor
I've used these a lot!
