CGT Repair Manual
CGT Repair Manual
Anyone have access to one? I understand its not something that would be readily available digitally. Would be ok with a parts diagram even.
Trying to change the alternator on my old man's car. I don't see how it is possible without removing the water pump as well.
TIA in advance.
TIA in advance.
TIA in advance.
TIA in advance.
Porsche Original Parts
The parts catalog may not be much help, since it shows the alternator by itself in the Electrical section, and the water pump in the engine section. The water pump diagram may help some.
Took all the underpanels off. Confrimed need to remove the water pump as well. The top bolt is too long and won't clear the firewall. The alternator is actually mounted to the water pump, so water pump is going to come off, put the alternator on, replace some gaskets and everything goes back in.
If anyone wanted to replace their A/C pump, that's a breeze!
