European spec CGT Conversion to US
I'd be surprised if it would be feasible to bring one in from Europe. As far as I know, quite a few are heading TO Europe because of how weak the US dollar is.
It's actually pretty easy. However, more have gone the other way, as I am sure others will chime in. The parts might be laying around! This car was built to one standard, the biggest (relatively minor) items would be Bumpers (markers and) and instruments.
To do this runs against economic logic though; since you have a better chance of finding the desired car in the US (all else being equal).
Here is the full list of items to convert from European to US spec.
LIST OF CHANGES FROM C00 (GERMAN SPEC.) TO C02 (US SPEC) - PER OFFICIAL PORSCHE DOCUMENT
- Front covering with additional sidemarks
- USA specific main headlights (modified road illumination)
- USA specific tail lights (direction indicator red instead of yellow)
- Abolition of rear fog light left, including switch on instrument panel: in exchange, a second back up (reversing) light is fitted
- Outside door mirror on driver's side flat (instead of aspherical)
- USA specific license plate holders (smaller)
- USA specific labels (including adhesive labels)
- Radio remote control 315MHz (instead of 433 MHz)
- Inflation pressure monitoring transmission frequency 315MHz (instead of 433MHz)
- USA specific instrument cluster (mph instead of km/h, F instead of degree C) [probably not changed is UK C16 car is donor]
- USA specific navigation CF for radio navigation
- OBD II (instead of EOBD)
- ORVR (additional leak diagnostics fuel tank system)
- Ends -
Hope that helps.
Kind regards
Steve
- Ends -
Hope that helps.
Kind regards
Steve
- Ends -
Hope that helps.
Kind regards
Steve
- Ends -
Hope that helps.
Kind regards
Steve
