My Macan turned into a boat! Navigation and GPS issue
According to my sat nav on my 2017 GTS, my car is driving in the Long Island Sound! The navigation system is messed up, and has me about 100 miles from where I actually am. This has happened twice before. When I check the system it is showing 0 satellites connected. Any ideas on the issue and a fix? I don't want to spend time at the dealer if it can be avoided. Thanks !
Unique Title
My first thought is the cable to the gps antenna has come loose or broken. My 997 behaved the same way after the tech who replaced the cabin air filter didn't reconnect the lead properly and it came loose. I'm not sure where the antenna is located on the Macan, though.
Hi yes, It was a loose connection at the antenna, which is located at the top middle of the windscreen somewhere inside the roof module. The dealer fixed it in 10 mins. It has now happened again, right after I got a cracked windscreen, going into get fixed again once the screen is replaced.
No reception on GPS
I have a PCM 2.1 in my 2006 997 first série. My GPS stopped working. On Status shows 0 satellites. Is the GPS antenna inside the Navigation box, or somewhere else outside? Thanks for any help ,
Here you go
https://workshop-manuals.com/porsche...ce_and_repair/
siberian
The best long distance runners eat raw meat, run naked and sleep in the snow
siberian
