MACAN GTS Front License Plate dilemma
#62
Too late for what? If you have the factory installed front mount then the holes have already been drilled in the bumper.
#63
When we took delivery in May, the front license plate mounting bracket had not been dealer installed. Dealer had put it under the trunk floor next to the spare. I don't run a front plate on any of my vehicles and haven't been hassled though UT state law requires one.
#64
#65
Unfortunately at this point, your only option is probably some decent bumper plugs as you mentioned.
#66
Can I know which mount did you use and where can I buy it from? I have a 2016 Macan S and I am looking for a similar solution that is centered, doesn't need holes in bumper and doesn't mess with the sensors.
Thanks!
#67
Carbonio offers a center mount solution that does not interfere with parking sensors, does not require any drilling or adhering of anything to the car, & can be installed and removed in seconds:
https://carbonio.com/collections/por...se-plate-mount
#69
I might be interested in the carbonio, but are there better pictures from side view, etc? Website is lacking with good pics tbh.
#70
T3X4S (11-09-2020)
#71
I found Sly Brackets when searching around for a no drill option--it's built extremely well and and once you get it assembled is very easy to use. It is essentially three parts: two clamps and one plate frame. When you screw the plate frame to the clamps, that is what tightens the clamps onto the grille--extremely smart engineering.
https://www.slybrackets.com/store/
#72
I like these solutions. Anything to avoid drilling.
Does the Porsche factory have to put on a plate even for just getting it transported to the ship? European delivery I can accept.
#74
Transported to port NO but European Delivery YES. We have had a number of customers do European Delivery and take our mounts with them. We have even shipped them straight to Porsche for installation before European Delivery.
#75
Thanks Carbonio. I'll contact in a few months when my Macan arrives at dealer.
