Macan 2014-Current
H&R Springs: How Much Neg. Camber?
Old 04-30-2017, 03:13 PM
NC TRACKRAT
NC TRACKRAT's Avatar
Default H&R Springs: How Much Neg. Camber?
It's my understanding that negative camber cannot be adjusted on the Macan. On a PASM w/steel springs application, when you checked alignment to adjust toe, what front and rear negative camber did you get after installation of H&R lowering springs?
Old 05-11-2017, 04:56 PM
NC TRACKRAT
bump! Surely, someone on this Forum got the H&R lowering springs besides us. If so, did you get your alignment checked? (You should've) Did you get a "before-and-after" read-out? Would really appreciate a reply.
Quick Reply: H&R Springs: How Much Neg. Camber?
