PDK service
The following is from the 2015 Porsche Service Information/ Technik Introduction for Macan, Macan S, Macan Turbo, page 104: "Transmission Type DL501-7A" When I google that it describes the Audi S-Tronic DSG transmission. I conclude that my Macan PDK is a Porsche adaptation of the Audi dual clutch 7-speed DSG as found in my Audi S4 and other Audis. At about 70K on my S4 I had mechatronic-electronics trouble. I hope the Porsche version is less problematic. I had the DSG serviced at two normal intervals on the Audi S4 and, yes, there are two separate fluids used. A gear lube for the gears and diff and an ATF type fluid for the wet clutches. I'm assuming the Macan PDK is similar.
