AC Evaporator Freeze Up
First really hot and muggy day today, and after an hour on the road no airflow from AC. Parked for an hour, big puddle of water under car and airflow is back. Seems like evaporator froze. Has anyone else experienced this?
HT,
I'm not familiar with the Macan, yet, however most ac system designs have an thermo probe sensor located inside the evaporator core to regulate compressor on/off. Assuming your model is like 'most,' and its new, I'd say you have probe sensor, or hvac controller, failure. If you have a 2015 take advantage of your warranty: drop it off at the dealer, get a loaner and let them handle the worry.
Griff
http://griffiths.com/porsche/air-conditioning/
Griff
I just had this exact same issue, 2 days in a row. My Macan is 3 weeks old and has less than 800 miles on it. An hour into a trip AC air flow was almost zero. It's going to the dealer tomorrow.
Did you find a fix to yours??
Not yet, I don't live anywhere near a dealer and need to plan a trip to get the car there. I also fortunately live where windows open is fine most of the time. Will try to get it to dealer by end of month. Please post if you learn anything more taking yours in.
Yes, I have the same issue on my 2015 Macan S. Took to dealer last fall and they found nothing wrong. The problem recurred last weekend on a humid day while driving from Chattanooga to Atlanta. I do not have a fix yet.
If you find the ac is working perfectly for a period time in your drive and then it starts to degrade (warmer air). And, say you stop the vehicle and park for 15 minutes with AC off, notice a puddle of water under the car after waiting, you start the AC again it seems to work again.... the evap core is freezing up: defective temp sensor in evap core, control head, or location of sensor in evap core has to be changed.
If you find the ac is working perfectly for a period time in your drive and then it starts to degrade (warmer air). And, say you stop the vehicle and park for 15 minutes with AC off, notice a puddle of water under the car after waiting, you start the AC again it seems to work again.... the evap core is freezing up: defective temp sensor or control head.
FWIW I had the same problem - dealer said it was delivered low on freon and added some to bring it to the proper pressure.
It happened twice after about an hour of driving in hot / humid Weather. Since the fix I have not driven the car for the same length of time. I a, sure I will and I will report back.
Unique Title
This problem is occurring on my wife's Macan S. It has happened on three occasions. She brought the car into the dealer who scanned the diagnostics. They told her that Porsche is aware of this problem but has not figured out a solution at this time. She is now on a future recall list for when (HOPEFULLY) they come up with a solution. They suggested turning off the system for a few minutes when it occurs.
