Towing
#77
I came to the same conclusion : Ma can not towing.
Well, a "Porsche" ..with a single piston caliper on the rear, ..looks a bit like a joke, no ?
..Or may be, we have to sell our P track cars and go Radical
#80
PCNA Macan Published Tow Rating As Of July 2015
Just to be clear, since this thread has some older posts, the PCNA tech specs for the Macan as of 7-28-2015 say "Towing Capacity = 5291 lb braked, 1653 lb unbraked".
#81
#82
Link To Porsche USA Macan S Towing Specs
http://www.porsche.com/usa/models/ma...turesandspecs/
Look under the section labelled "Body". You will see 5291 lb braked trailer capacity.
#83
Yep, there it is, plain as day. 5291 pounds. Black and white.
"Towing capacity (braked / unbraked) 5291 lbs / 1653 lbs"
Yesterday I Googled the Porsche website. When I drilled down I saw the 4409 number. Bizarre.
