Macan 2014-Current
Clock keeps losing time
Old 11-21-2020, 12:30 PM
siberian
siberian's Avatar
Received 2,221 Likes on 1,325 Posts
Default Clock keeps losing time
Anyone come across this? The main clock loses minutes over a day or so? No not a weak battery, any ideas? This is for a 2020 Macan S, TIA
siberian
Old 11-21-2020, 02:19 PM
Terry Adams
Terry Adams's Avatar
I am not a scientist, but you do live in Alaska.
True North or magnetic North? Coriolis? Russian hackers?
JK cause I have no idea.
Old 11-21-2020, 02:31 PM
siberian
siberian's Avatar
definitely an A for effort, no banana but clearly thought of the issue (did leave out the North Koreans though)
siberian
Old 11-21-2020, 04:19 PM
dml
dml's Avatar
You are driving too fast. This is relativistic time dilation. Do objects in front of you look bluish?
The following 2 users liked this post by dml:
blazen244 (11-24-2020), tk-porsche (11-28-2020)
Old 11-21-2020, 04:49 PM
siberian
siberian's Avatar
Having spent 14 years in high energy physics, I'm vaguely familiar with the concept of time dilation (especially near the event horizon) but I believe the KISS principle is perhaps more apropos in this case.
(It) Seems, and of course this still needs to be verified by 3 separate and independent labs following the Fleischman-Pons cold fusion bs back in the late 80s, but "someone" (we don't want to be pointing fingers here do we?) when changing from the inane summer time to regular time (why we need 22 hours of daylight instead of 21...) disabled the previously set (hearsay as TOWMBO claims she never went near the inertial dampers - which I told her NOT to disable under any circumstance) "use GPS" for time resulting in the made in North Korea clock to loose time.
Having now, as is common in Porsche vehicles and order forms, checked the box, I expect time to return to it's normal entropy settings... Should this not solve the issue I'll re-post from the past...
Thank you for your creative suggestions!
siberian
dml (11-21-2020)
Old 11-21-2020, 06:17 PM
n2cars
n2cars's Avatar
Does your clock go into "sleep" mode when the vehicle is not being used? Both hands go the 12 o'clock position?
Old 11-21-2020, 06:59 PM
siberian
siberian's Avatar
Yep
siberian
Old 11-23-2020, 11:51 PM
JDailey
JDailey's Avatar
A friend of mine had a "clock issue" on his 2019 Cayenne S Hybrid. The clock wouldn't keep time properly. It ended up having something to do with his GPS system and the integration with the clock. Here's the link from the Cayenne forum:
https://rennlist.com/forums/cayenne-...rid-clock.html
Old 11-24-2020, 12:23 AM
siberian
siberian's Avatar
Thanx! For the time being I'm keeping a loose eye on it (as other mechanical issues on the burner) to see now that I've set it to GPS rather than manual it will keep better time.
siberian
Old 11-24-2020, 12:50 AM
blazen244
blazen244's Avatar
I loose time on two of my vehicles and like you batteries are strong I just live with it now
Old 11-24-2020, 01:02 AM
siberian
siberian's Avatar
It's these little details, like an auto start you find on $25k vehicles and clocks that actually keep time that you just really don't want to experience from P. But as was stated a quartz Timex keeps better time than a Patek Philippe.
Still annoying
siberian
Old 11-24-2020, 10:27 PM
Terry Adams
siberian
Your Macan is too new to have a problem like that described here, but I had a similar clock issue that started last year in FL and got trouble shooted by the local P dealer. Battery and alternator were good, but would not charge battery, dead over night unless kept on a Porsche charger. He resolved it with new positive terminal post and wires. Expensive, mostly labor.
See post #52. https://rennlist.com/forums/997-foru...esolved-4.html
Old 11-25-2020, 12:21 AM
siberian
siberian's Avatar
Thanx for the heads up. Been busy with pressing stuff so I haven't had a chance to check whether now that it's on GPS set time it's back to keeping time. I'll definitely keep your suggestion in mind. Thank you!
siberian
Old 11-28-2020, 07:00 PM
PSEE
PSEE's Avatar
trouble shooted?
Ouch!!!
Old 11-28-2020, 07:07 PM
siberian
siberian's Avatar
not yet... patience grasshopper...
siberian
Quick Reply: Clock keeps losing time
