Macan 2014-Current
Clear front side markers
Old 06-14-2019, 07:17 AM
  #61
TRAKCAR
TRAKCAR's Avatar
Received 1,586 Likes on 734 Posts
Old 06-16-2019, 05:54 PM
  #62
Sincity
Sincity's Avatar
I just happened to find them on Suncoast and glad someone has bought and installed them.
EDIT-found them on eBay for $45.99 shipped.
Old 06-19-2019, 11:09 AM
  #63
kash101
kash101's Avatar
anyone have the tinted ones on a darker spec? I have a volcano grey and thinking about these.
Old 06-19-2019, 11:34 AM
  #64
GoBlue!
GoBlue!'s Avatar
Do it without hesitation. I have them on my jet black and it looks much better. Even a closer match on volcano. There are pics on the macan forum on a volcano, I think in the flat 6 thread.
Old 06-19-2019, 12:19 PM
  #65
AxionJaxon
5th Gear
AxionJaxon's Avatar
On Agate Grey Metallic.
rna352 (06-20-2019)
Old 06-20-2019, 10:24 PM
  #66
rna352
rna352's Avatar
As if you needed more convincing, here's yet another tinted on Agate:
Old 06-21-2019, 11:48 AM
  #67
kash101
kash101's Avatar
looks great. ordered. thanks
Old 06-26-2019, 04:57 PM
  #68
DB_NC_95C2
DB_NC_95C2's Avatar
Originally Posted by KM1959
I brought mine to a tint shop and tinted them dark. Although my car is black (so it blends very well) I can't imagine it looking worse than the amber on every other color - especially with all the existing black trim parts.
ditto, smoke grey on mine, looks just fine, the Suncoast smoked ones were TOO thick and did not fit the lenses well, I sent them back
Old 06-27-2019, 12:10 PM
  #69
jhbrennan
jhbrennan's Avatar
Trying to visualize what didn't fit - can you explain some more? Thanks.
Old 06-27-2019, 01:01 PM
  #70
DB_NC_95C2
DB_NC_95C2's Avatar
They were a bit too long and a bit too tall, and with the extreme thickness, they just didn't 'hug' the lenses as well as a custom film applied by a pro
Old 06-27-2019, 04:05 PM
  #71
Dr. Ferdinand
Dr. Ferdinand's Avatar
Thanks for sharing guys, was very curious to see what the tinted ones would look like on an Agate, been rocking the Lamin-X covers on my Agate T for the last couple of years (given lack of options) so may just opt for these. This is what it looks like with the Lamin-X film:
Old 06-27-2019, 09:45 PM
  #72
Sincity
Sincity's Avatar
Holly smokes......what method did you use to lower it and are you on spacers?
Like another person above, I bought the same side markers on eBay and had an issue with the driver side not always lighting up. I resolved it by reversing the bulb adapter.
Old 06-27-2019, 10:25 PM
  #73
Dr. Ferdinand
Used what I personally think is the best method for our platform (but not the cheapest ) - H&R Air Suspension module. It's by far my favorite mod, rank it higher than the Cobb AP. Works very similar to a 'piggy back', it is a module that plugs in your PASM module (in the trunk), under 60 mins install and can go back to stock with a bypass without even taking it out. This is the out-of-the-box setting, a further 30mm drop is possible (and you can regulate front and rear separately).
Running a modest 10mm spacer all around (with extended lugs). And now that the Michelin Pilot 4Ss are finally available on our 265/295 21' fitment (can thank MB AMG GLC 63S for that), she handles sportscar-like, and finally have the handling buttoned exactly where I want it.
Old 06-28-2019, 01:14 AM
  #74
///Bruce
///Bruce's Avatar
Two questions
1. Can you keep the lowered height at speed?
2. How harsh is the ride, at what drop value, what settings selected?
Old 06-28-2019, 12:02 PM
  #75
Dr. Ferdinand
Originally Posted by ///Bruce
Two questions
1. It is setup that above 43mph (or thereabouts) the height increases for added comfort
2. Not harsh at all, I would describe it as firmer and more sporty, but wouldn't at all call it harsh (in a kidney jarring way) I have been largely driving it from the out-of-the-box setup and I find it just perfect, played a bit with the settings (even just for the heck of it giving the Macan a 'gasser' look LOL, so the ride gets noticeably firmer [less suspension travel] as you drop it to the extreme, naturally)
One of the immediate distinctions from a feel perspective is the noticeable decrease in body roll (e.g. taking spirited turns over uneven pavement). A lot more controlled, composed, and planted now, which makes sense given lower COG.
Quick Reply: Clear front side markers
