Need help finding a GTS
RL'ers. I am looking for a 2018 GTS (new) with the following options:
1) Red or agate gray interior
2) Trailer / tow ball
3) Connect (for Carplay)
Everything else is negotiable. Anyone see sanything at their local dealer?
The porsche inventory search is terrible. You cannot search on options and difficult to go outside of area. PCARFINDER.com is better.
I need access to Porsche internal systems.... or use the rennlist network.
The two dealers I do business with in my area don’t have any GTS models that meet your criteria (barely any GTSs at all in fact). Seems the GTS inventory is running low at this point in most locations I’ve seen.
With GTS inventories shrinking, if these options are all mandatory for you, I will offer that you might want to also consider the #2 and #3 can be added by a dealer to any vehicle. If a dealer tells you otherwise, they are wrong. I know it is ideal to have all factory options but this is at least a last resort you might use if you find an otherwise desirable vehicle. I am sure you could negotiate a reasonable cost for the dealer added option as part of the sale. For example, my dealer lists a GTS on their site with 1 & 3 but no #2 hitch. Good luck with your search!
