Driver's door rattle
2015 Turbo, 14,000 miles- I took it to the dealer for misc squeaks from doors and a driver's door rattle after trying the suggested treatment of the door weatherstripping. Dealer took it to the body shop they use to adjust the hood, also replaced the exterior trim pieces that border the bottom of the front windows on both doors. They also treated the weatherstripping on all the doors. All of the noises are gone - except the faint rattle in the drivers door. Any suggestions?
Had a rattling noise coming from driver's door, but it sounded like it was from inside the door, so I asked the dealer to take off the door panel (not sure what you call it, but the internal panel that covers the whole door). When they did, they found a piece of plastic broken off from something and sitting there inside. Not sure where it had come from, but once they removed it the noises were gone. Maybe have them open-up the door panel.
Update on squeaks / rattle: I took the car back in to Porsche North Houston as the rear door squeaks returned ( apparently when the lubricant wore off) and the driver's door rattled when the window was in the up position. This time they replaced both rear door window guides and seals, and the driver's door window guide. Problem solved!
