Macan 2014-Current
Safe cleaning method for black PSE exhaust tips?
Old 06-18-2018, 06:44 PM
CarGuyNVA
CarGuyNVA's Avatar
Default Safe cleaning method for black PSE exhaust tips?
Has anyone cleaned/polished their black chrome OEM PSE exhaust tips as comes on the GTS? If so, what’s safe that won’t harm or remove the finish?
Old 06-18-2018, 08:56 PM
CarGuyNVA
CarGuyNVA's Avatar
Okay, I went ahead and used an old standby, Meguire’s liquid cleaner/wax. Always a very mild cleaner and effective. It did the trick beautifully.
If anyone has additional suggestions, still love to hear them.
Old 06-18-2018, 11:27 PM
Mark in Baltimore
Mark in Baltimore's Avatar
I just use Adam's car wash shampoo and then Jescar Powerlock.
Old 06-19-2018, 09:18 AM
BradB
BradB's Avatar
Avoid using abrasives and be careful even with cleaner waxes as they can have abrasives in them and scratch, too. It’s best to adopt a wiping/rubbing strategy so all your cleaning motions are the same direction (just as you would on paint) so any light scratching/marring over time will be far less noticeable. It’s best to clean really well once then seal with a quality sealant or coating. I use Optimum, FWIW. Wipe the pipes, especially the edges that get sooty, very often. Once sealed/coated this is super easy since dirt/soot doesn’t stick.
Old 06-20-2018, 08:43 PM
CarGuyNVA
CarGuyNVA's Avatar
BradB, much appreciated. The brand/type of cleaner/wax that I used, I did so specifically because it has zero abrasive cleaners and only a mild chemical cleaner. I was concerned about the particular black chrome finish of these tips as I have not worked with that before.
I agree on the ‘keeping them clean often’ approach too. I did that religiously for the sport tips on my previous CTT and they stayed pristine.
Thanks again for the suggestions and advice!
Quick Reply: Safe cleaning method for black PSE exhaust tips?
