Macan 2014-Current
dull front caliper finish
Old 07-24-2017, 10:30 AM
johneg
johneg's Avatar
Default dull front caliper finish
2017 Macan 2.0L front brake calipers are a dull flat black finish compared to rear gloss black finish.Vehicle has 3000 miles.Normal or not.Thanks.
Old 07-24-2017, 07:26 PM
Wheel Dynamics
Former Vendor
Wheel Dynamics's Avatar
Stock finish on the calipers sometimes are bad, you can get them refinished, maybe a different color...
Old 07-24-2017, 08:40 PM
doggarnporsche
doggarnporsche's Avatar
Mine has the same thing, I'm going to ask my dealer about this as it must be somewhat common. Also, keep an I on your wheel bearings. Myself and another are both getting our 2017 Macan 2.0 L car's wheel bearings replaced. They have already a upgrade to the wheel bearings.
Old 09-01-2017, 07:23 PM
johneg
johneg's Avatar
Default 2017 base Macan brake caliper finish
Received answer on front caliper finish from Porsche.During a recall for fuel gasket .i asked about front brake caliper finish,service writer was not aware but looked at others and said there all the same.Porsche USA tells me the finish is different because the calipers are a different size. I feel they understand there's a problem but don't want to admit because then they would have to correct.Maybe just not enough complaints.
Old 09-04-2017, 06:45 PM
El Sapo
El Sapo's Avatar
nm
Old 11-07-2017, 11:47 AM
tneocli
tneocli's Avatar
I am trying to get them to replace mine as well. Its disappointing
Old 11-07-2017, 11:50 AM
tneocli
tneocli's Avatar
Could you tell me any info you have regarding the bearings? I hear a noise from my front wheels. Im concerned it might be bearings.
Old 11-07-2017, 05:37 PM
Mark in Baltimore
Mark in Baltimore's Avatar
Merging the two threads you started on the dull brake caliper finish.
Old 12-19-2017, 04:08 PM
tneocli
tneocli's Avatar
Porsche has agreed to replace my front calipers due to the dulling/discoloring making them different from the rear
Old 12-19-2017, 04:18 PM
El Sapo
El Sapo's Avatar
Mine are different finish but it doesn't bother me. The front finish is not as smooth. Figure I can deal with it until I replace it with a 2020 GTS
Old 12-19-2017, 04:24 PM
tneocli
tneocli's Avatar
I am doing the same thing however I have a good relationship with my service dept and they got Porsche to replace them when it went in for some other warranty work.
Old 12-19-2017, 07:36 PM
El Sapo
El Sapo's Avatar
I can't say that I have a good relationship with my Service Dept. It's been a real frustrating experience for me. Getting an appointment took me months. They were disjointed and unorganized when I did get in. Passed me around to different service agents and I never got answers to a couple of problems/questions. I did see my comments were written up so if anything does come up again in those areas, I can say told you so. This is a different dealer than where I bought the car. Shouldn't make a difference right? They treated me like a red haired stepchild. I also wonder if the service load for the increased number of cars they're selling is effecting the quality of their service. I have 4 dealers in the area to chose from. I think I'll take my car somewhere else next time.
Old 12-20-2017, 12:08 PM
08flatfour
8th Gear
08flatfour's Avatar
Have seen this on a few of our shop's Macans.... avoid wheel acid during car washes! certainly doesn't help
Would recommend trying your dealer of choice first to have them run it by their porsche rep to see if PCNA will help, if not, weekend project!!! (if you're up to it / able)
Cheers
Jeremy
Quick Reply: dull front caliper finish
