WTB Bosch M4 ABS for 991 Cup
I am looking to buy a Bosch M4 ABS system for my 991 Cup. I am about to pull the trigger for a system and figured I would do a quick ask here just in case someone had a system they were not using or you took it off to run a spec class. I am a buyer right away, just send me a PM and I will get back to you right away.
Also, if anyone knows the best place to buy a system, please post it here and I am sure it would be a help to others looking for an ABS system.
So far, seems like the best pricing for a retail system is from Autometrics Motorsports, any comments on that system would be appreciated. I am told their system may not have the balance adjustments, not sure? Please chime in with any comments.
Thanks,
Chris
Thanks,
Chris
Im going to be selling my basically new Teves Pro ABS (same as installed on the 997 GT3R and many 997 World Challenge Cars)
Will sell with custom wiring harness and all sensors needed to plug and play.
The Teves system is great. Installs nicely, is a bit more stand alone than the Bosch setup. both have motorsports military grade harnesses and nice features. I would think all come with adjustable settings, though I think with the Teves, we had to buy a third party adjuster and then based on the values from that adjuster it would send the value to the system ie 1 to 9; whereas I think the bosch just comes with it out of the gate. I personally found the bosch the very top of the line, but also top of the line pricing. I think pricing has come down from like 12 to like 8.
if you wanted to seek used units, one suggestion would be to go to racecarsdirect and post a WTB. I think all those 991s in like supercup and one of those other series allow it and they all have them. I looked at a few 991s from over there, and literally all had it, and they put them in and pull out like water.
Thanks,
Chris
Thanks,
Chris
Yes. The switch is what I am referring to. Should have said setting adjustments. I have noticed that there were a few different Bosh systems offered by the other vendors and was not sure if it was the adjustment setting capabilities that were different, or simply the length of the wiring harness that hadn't been custom sized? Also, I read that the slip can be adjusted/unlocked for like traction control?
