Navigating A Nitrogen Supply System
#46
What is the benefit of higher flow or full pressure immediately in the PCA race context
Can someone explain the difference between Industrial and European interchange fittings?
If you are setting up a system and to preclude compatibility problems, try to keep all the fittings the same standard.
#47
I didn't want to fool with setting up a system, so I had my shop put all the fittings, regulator and hose together. They had all the hoses assembled at the Parker store and they came with the pressure release fittings. As some have said the airjacks will work with pressure around 300 to 400 ft/lbs but to get them to rise quickly you want be around 500 ft/lbs.
high pressure regulator
release valve opened
The following 2 users liked this post by skxf430:
arrowheaddoctor (11-14-2021),
carbondan (11-28-2021)
#48
Just what I've been waiting to hear. I was considering the same thing myself after I saw the prices they wanted for the dedicated carts. In the end, I took the lazy route and bought one. If you decide to pursue this let me know and I'll send you some detailed pictures of my Paoli cart to use as a mule.
By the way, if you want to buy one, here's a link to the cheapest shop:
http://www.demon-tweeks.co.uk/motors...le-trolley-kit
Add $150 for shipping and you're there. I bought mine directly from Paoli and the shipping and fees from Italy doubled the price. The advantage of the Paoli cart design is it mounts the regulator separate from the cylinder so it's allowed on and over the pit wall.
#49
I gave up searching so I'm having my local cage builder replicate the Paoli cart using the Harris regulator separated from the tank. Will post back after I get the final price.
Darkstar1 (11-12-2019)
Scott. (11-10-2019)
#51
Manthey Racing sells a setup that looks like a re-branded Paoli bottle.
You can always buy a nice aluminum cylinder from Catalina Cylinders.
https://www.catalinacylinders.com/ma...ltyindustrial/
#53
Basic Sponsor
Ed
https://demonspeed.com/
Engineered Race and Track Products for your Porsche
https://www.goodaero.com/
Race Designed Aerodynamics
https://racingtirewarmers.com/
Win more races with tire warmers
Great products for racers by racers
ed@demonspeed.com
Demon Speed Motorsports is a proud sponsor of PCA and the Club Racing Program
ed@demonspeed.com
Scott. (11-13-2019)
#56
Thanks again for the thread contributors! I purchased all of the parts mentioned above and was able to replace the first adapter with a swivel Krontec that has a 3/8" output from the same vendor since I'm using Krontec jacks.
#57
Progress picture from the cage builder using the Harris regulator and the Amazon AL tank. Still need to decide on the tank strap, add in hose and wand holder. He said it's a PITA to build and see why the Paoli ones are so expensive.
My local Air Gas is filling one of the AL cylinders and should be back in one week from the filling depot. They don't have the extension hoses for the remote regulator and need to find a solution for that soon.
#58
Project complete and just waiting for the custom Raterman hose to connect the regulator to the tank for the custom cart. Here's the part numbers and can be ordered from one of their distributors (ie air-gas) or if you have your own company. I'll report back if the hose doesn't work after the two week wait time to make it. Definitely saved a lot of money vs. buying the Paoli gear.
FPS-A-45P-18-F14
CG 580 Nipple
CG 580 Nut
FPS-A-45P-18-F14
CG 580 Nipple
CG 580 Nut
