PS Line Removal Help
I have a small leak around the Power Steering reservoir where the return low pressure line enters. The red sleeve is all chewed up too....
Anyone had an issue like this or have an idea how I can get it apart?
Yes. This happens a lot and unfortunately it's difficult to repair without replacing the entire power steering reservoir.
I ended up putting in and an8 fitting and cutting the line and using an 8 an push lock fitting. This solved the leaking issue.
