FS: ADL2 Motec Dash Logger
Former Vendor
I'm selling a spare Motec backlit ADL2 dash logger - $3K
It's a Porsche supplied unit that is still as it came from the factory (4Mb, Porsche 30 I/O channels, programmed for the shift light module, i2 standard). It should be pug and play for a 997 cup car but useable for other cars. I have the codes to unlock it for use with other ECU's also.
Mark
Mark
Can you clarify please--stock Cup ADL2's are 1Mb and 22 I/O. And it'll be comm-channels locked requiring a code from PMNA...
Former Vendor
The dash came out of a European cup car so I don't know how it was set up by Porsche originally. The serial number is 18007-14471. Motec tells me it was a Euro dash and Porsche probably needs to unlock it. However, I have the CM comms and DL Diag Log passwords to unlock it for use with other ECU's, so I think that takes care of that issue.
I checked options and it shows:
4Mb memory and P30 I/O which I'm told is a Porsche configuration with 30 I/O channels. I can see that it is set up with shift light module logic already. I downloaded logged data that can only be read by I2 standard (not pro).
Mark
Mark
Here, in Europe, there is (was ?) an "option pack" for the 997.1 (don't know about the .2), that came with a memory upgrade, front and rear brake pressure, steering Wheel angle sensors, and, maybe, the I/O upgrade to accomodate the new sensors...
