GT3R Pedal Cam
Thanks. Yes, brake in psi (although you don't really see the initial spike in the video). Shocks in inches, ride height is a value of ~3.35 for the front and 2.7 for the rear. The right rear pot was acting up so the data is garbage.
I'm generally seeing about 0.3-0.5 inch of compression or rebound in cornering. Some spikes approaching 1 inch going over curbs. Shocks are set up with roughly 1 inch of bump travel before starting to touch the rubbers and 1.75 inch of rebound.
Wow thats soft
When i was running to soft i was hitting bump stop and i was running alot more spring. But i was pulling 1,8g
The tracks nearby are very bumpy - so I've been experimenting with going softer. So far it is slower....but I need to do some more tuning and I am also somewhat out of practice with driving right now - not ready to blame it entirely on the springs.
I have heard diffrent ways of doing it less spring and more dampening or vice versa
