Shift Light Module on the 2009 RSR
Hey Folks.
I need to know what is written on the sticker under the SLM. Itīs the plan of what is displayed with the different LEDīs on the SLM.
Has anyone a high quality photo of the sticker or the service manual of the car (where it is also explained in)?
Thank you in advance!
Btw: The Plan of the 2010+ Cups is already there... Need the RSR only...
See the photo below:
Bigger Photo:
http://www.automobilesreview.com/gal...gt3-rsr_04.jpg
and I still can't read some of it. Guesses are (?)
Warning Light
Fuel RES Light
Up Shift Light 3
Up Shift Light 2
Up Shift Light 1
PDM Fault
High Beam
Flasher
Ignition On
TC Action
_C (Service?)
Warning Light
Fuel RES Light
Up Shift Light 3
Up Shift Light 2
Up Shift Light 1
PDM Fault
High Beam
Flasher
Ignition On
TC Action
_C (Service?)
If you connect to the dash and use the ADL manager, click on the "shift light module". you should be able to see how the dash is set up. Most times. flashing lights in the corners means wheel lock up (different colors for front and rear). Usually all flashing means pit speed limiter is on
Former Vendor
We have a 2009 RSR in the shop. Ill review on Monday and see if i can take a close up snap photo and post it. email me direct , steve 'at' zsaracing.com if you dont see a post monday. means the brain did a shut down.
Bigger Photo:
Warning Light
F(uel?) (RED?) Light
Up Shift Light 3
Up Shift Light 2
Up Shift Light 1
(PSM?) Fault
High Beam
______(Flasher, Starter, Pusher, Panther?) :P
Ignition (On?)
TC Action
_C (Service?)
Warning Light
Up Shift Light 3
Up Shift Light 2
Up Shift Light 1
(PSM?) Fault
High Beam
Ignition (On?)
TC Action
_C (Service?)
Hi. Steve asked me to photo the SLM schematic.
I hope it helps. Any other questions on the 996 or 997 RSRs, please feel free to ask.
ZSA Racing
info@zsaracing.com
ZSA Racing
info@zsaracing.com
