Slick Tires
Slick Tires
Quick question before i mount my tires: Got a nice set of 'little' used Michelin slicks and thought about rotating the tires. So the original outside goes inside now. Is this possible ?
If so its hit-n-miss. Most of the GT3 cars here don't have that issue.....
To the OP, yea flip them on the rims but also switch them side-to-side. This keeps them turning in their orignally mounted direction but gives you fresh rubber on the inside. I do this literally to every set of slicks I race after 4 HC's. RF to LF, RR to LR. Capiche?
@ Spare tire (very ON topic name): I have the 27/65 rears and 24/64 front and this fits perfect.
You are right about the 27/68 tires. They are theoretically too high. I tried it once, and it seemed as if the ABS corrected itself after a couple of laps. Drove without any issues for half a day.
@JR: Thanks for the advice.
When i tried the cup car 27/68 rears my ABS lit up and blinked ABS brake failure. And when I tried to ignore it and brake hard figureing I would just lose the ABS. Wrong. The bias was way out of whack and It was like I only had calipers on the front and they jumped into ABS long before any real speed had been removed. now i use the 27/65 same as dass and they are great. And Cheaper!
