2007 Cup Brake Bias
2007 Cup Brake Bias
Hey guys.
Just wondering what brakebias you use?
had the second drive with my 07 cup a week ago, and had some troubles finding my bias setting.
i tried all the way from 0 to 7 or something like that.
I have to say, that i had a front right lockup, and ruined a brand new tire.
After that i tried to adjust a bit.
unfortunately i did that while braking in brand new rain tires...maby not the smartes move.
however i just wanted a base-setting i can adjust to my needs from.
Can anyone help?
thanks
Can anyone help?
thanks
The setting on the MoTec dash is somewhat meaningless until you know what the bias is at each setting (%front vs. rear). If you have access to someone that knows MoTec well, they can work with you to set a base setting to be exact. If you don't have a decent MoTec technician, put some regular but older tires on, find a long straight on the track and stand on the brakes. Find whether front or rears are locking up and give two full turns in the opposite direction and re-try. Stand on brakes again and adjust further.
