Solid lift or hydraulic?
Sorry, don't have any lash caps or followers around....I might have a set of titanium valves, some valve springs and retainers but I have to look around. Not sure if I want to sell that stuff or not either.
The heads I have are bare castings with one damaged. I will throw them in for very cheap if you want the cams/camboxes. I believe rs hrads use a bit larger valves and have different port shapes than a cup.
